1977 KZ 1000 b1 LTD running rough
- kenskz1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Also... 1200x1200 pixels max size too.
GL.
:laugh: Patton will be along soon with pics! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- davelKZ1000
- kenskz1000
- davelKZ1000
- keith1
rule out some air leaks and try it....valve adjust is next....check your pm's......
- keith1
- davelKZ1000
- keith1
and see what clearance is...write this shit down...see if two of the ehuast are 180 ...check them too and write it down......rotate around till the other 2 are 180 away...measure.....you get the idea.....
- TeK9iNe
I just checked volts to coil and if I did it right I got 10.8 on both
:woohoo: 10.8 is WAY NOT ENOUGH for anything..you should have nearly exactly the same voltage at coils as is at battery.
13+ Volts once idling.
Fix this first!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
Fix this first!
my bike has the same voltage....how do explain good plug readings, great driveability(never a fart or a hiccup) and bike starts by breathing on the button hot or cold?....i m just wondering....
- davelKZ1000
if you have it on the side stand, oil will collect in that area....dont sweat it....i take it you are checking valve clearances?....take the plugs out to make it easier and use the kicker or pull ignition cover where points live and use 17mm and 17 mm only to turn motor over untill 2 of the cam lobes are facing 180 away from buckets...get your feeler guages
and see what clearance is...write this shit down...see if two of the ehuast are 180 ...check them too and write it down......rotate around till the other 2 are 180 away...measure.....you get the idea.....[/quotok
I am a little confused about checking the valve clearance......
OK you saidwhen they are facing 180 away from buckets...the books said turbot until the markes on the can chain spoket thing lines up with the engine.
So the ones I'm checking are at percicely 180 from the buckets not 90.right
