Tore it down a bit.......
15 Dec 2009 15:53 #339145 by keith1
Tore it down a bit....... was created by keith1
well, in light of the recent crop dusting on cold start-ups as soon as oil pressure comes up and the amount of metal stuck to drain plug magnet( a lot more than i m comfortable with), i spent a couple hours after work and pulled head...no surprises and i didnt find any blatant reasons....
a couple questions though.....is it normal for head to be real dark near exhaust cams and the whole garage stinks of rancid oil....? also i have a valve that looks "wet"...i ll post up some pics.....let me know if you see anything....thanks
15 Dec 2009 15:54 #339146 by keith1
Replied by keith1 on topic Tore it down a bit.......
22
15 Dec 2009 15:55 #339147 by keith1
33
15 Dec 2009 15:56 #339149 by keith1
44
15 Dec 2009 15:57 #339150 by keith1
55
15 Dec 2009 15:58 #339151 by keith1
kids had to take one too!!
15 Dec 2009 16:30 #339157 by roy-b-boy-b
Replied by roy-b-boy-b on topic Tore it down a bit.......
How do the valve stem gaskets look like? Roy
  • TeK9iNe
  • What did you do!?!
15 Dec 2009 16:31 #339159 by TeK9iNe
Replied by TeK9iNe on topic Tore it down a bit.......
From what I can see, it looks pretty good. Unless thats rust in there...
If rust, then you should try to take some longer trips with the bike more frequently, so the oil can get hot enough to boil out all the moisture.
The shiny valve is likely oil that has leaked past the seals. Not uncommon with the regular seals and new oils when they get hot.
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
15 Dec 2009 16:44 #339163 by keith1
roy,if you mean valve seals, i m going to pull the buckets and take a peak when i get some time.....i m not sure how much i will see......
  • trianglelaguna
15 Dec 2009 17:20 #339176 by trianglelaguna
Replied by trianglelaguna on topic Tore it down a bit.......
never seen the brown build up that i can remember on the ten or so i've been in...no expert here but looks different than mine ever did.....smoke on start up is valve guide seals i believe...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
15 Dec 2009 17:26 #339177 by keith1
Cheers.
B)
i took a repeak......not rust, just discoloration...due to my own stupidity and rookie mistake, i ran this motor for quite a while with the cams out of phase...they were correct in relation to each other, but i was off a bit on the exhaust cam mark.....it should have been right at head level and it was about a half an inch higher...bike surprisingly went down the road well, but would nt idle for crap.....hence my schooling on vm26, vm28 bs34, 29 mm smoothbores.....i learned a lot about jetting and rebuilding and about people's character.......its all part of the learning curve......thanks for the input.....
15 Dec 2009 17:29 #339178 by keith1
i m gonna give the head a good lookthrough....i suspect problem is in there.....i dont want to throw any more money at this bike, but if i have to redo head , larry is going through it and its getting a mild port job......
