How to dry block your kz900/1000.
- zed1015
28 Sep 2009 03:35
Been asked how i dry blocked my z1000 motor so here's a basic guide with pic's.
Pic '1'.
The 6mm oil feed holes from the main gallery at the two back corner studs need plugging . This can be done with interference fit alloy bungs as kawasaki has done in the rest of the motor but i prefer to drill 6.8mm and tap m8 using loctited grub screws so that they can be removed if reverting back to the std setup.
Pic '1'.
- zed1015
Re: How to dry block your kz900/1000.
28 Sep 2009 03:44
Next.
The cylinder head has has four 6mm galleries that need the same treatment. These run diagonal from each of the four outer studs to the cams. Once this is done no oil can travel up or down the cylinder block and is therefore 'DRY'.
- zed1015
28 Sep 2009 03:55
Now you need an alternate external oil feed to your cams.
Here is the one of the four bungs that need removing (one at each corner). These can be drilled out direct or carefully drilled up the middle and tapped m5 to accept a draw bar type extractor.
Once out i drill and tap m10 the head to accept a 10mm banjo bolt and also spot face the casting to provided a clean flat sealing surface.
- zed1015
28 Sep 2009 04:10 - 25 May 2011 08:02
And here is my finished oiling setup.
I made some billet oil cooler take offs and inserted an alloy splitter block on the return side so that the head gets cooled oil.
The hose is Earls dash 4 which has a 5mm bore with banjo's specified to take a 10mm bolt.
The banjo bolts have been made by myself using 10mm allen bolts and have been bored 5mm.
I've run this set up for 10 years now on a couple of my zeds with no problems at all.
Hope this thread is of some help ?
Last edit: 25 May 2011 08:02 by zed1015.
- ben james
28 Sep 2009 05:17
what is the advantage of doing this.
regards ben
regards ben
- PLUMMEN
28 Sep 2009 07:58
zed1015 wrote:
that sir,is beutifull work!And here is my finished oiling setup.
The hose is Earls dash 6 which has a 5mm bore with banjo's specified to take a 10mm bolt.
- 9am53
- homebrew, and some bbq
28 Sep 2009 08:21
I am also a motorcycle dim-wit and don't understand the benefit of this...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
28 Sep 2009 09:53
eliminates oil being able to leak out of the base gasket or head surface.
zed1015 thanks for the write up,this should help several people out as this is a pretty popular mod people like to do but don't always know how.
did you notch the fins so the banjo clears them?
leon holmes
leon holmes
- zed1015
28 Sep 2009 10:01
ben james wrote:
Apart from looking really trick which is as good an excuse as any
it is mainly used on big block engines where the crankcase mouth has to be bored out to accept the bigger cylinder liners. When this is done there is a big reduction in gasket area around the rear oil feed which results in base gasket oil leakage and a resultant loss of oil pressure to the cams. Dry blocking eliminates this problem which could turn your mega bucks motor to scrap.
regards ben
- jordan
28 Sep 2009 10:09
wow, this is great. I am building a big block and was worried about this myself. Would you be interested in taking in heads to do the drilling adn tapping for the oil lines?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- zed1015
28 Sep 2009 10:09
531blackbanshee wrote:
Yes, I cut the away fins so the oil lines had a straight run and mainly just for cosmetic neatness but most people just loop the lines over from above or space the banjo's out away from the head.
leon holmes
- zed1015
28 Sep 2009 10:15 - 28 Sep 2009 10:16
jordan wrote:
Unfortunately i'm in england so shipping costs could be a problem . I'm sure any good mechanic or local machine shop will be able to do it with ease.
Last edit: 28 Sep 2009 10:16 by zed1015.
