How to dry block your kz900/1000.
  • BSKZ650
  • BSKZ650's Avatar
Re: How to dry block your kz900/1000.
28 Sep 2009 10:25
#324468
looks cool, but how do you return the oil to the pan?
77 ltd1000, current rider
76 kz900, just waiting
  • zed1015
  • zed1015's Avatar Topic Author
28 Sep 2009 15:24
#324502
There is no change to how the oil returns to the sump.
It drains back down as standard via the camchain tunnel located between the center cylinders..
  • fastestz1
  • fastestz1's Avatar
28 Sep 2009 15:49
#324505
what do you use to notch the fins?
thankyou
  • larrycavan
  • larrycavan's Avatar
28 Sep 2009 16:07
#324507
Beautiful Job!
  • timebomb33
  • timebomb33's Avatar
28 Sep 2009 16:56
#324517
thank's for all the pictures and info that is exactly what i was looking for and by the way i second larry nice job on a extra beautiful and nasty motorcycle you have done yourself proud.
I THINK MY POWERBAND BROKE
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
28 Sep 2009 18:38
#324534
I could be wrong, but I thought there were restricted orifices on the block to keep all of the oil pressure from going to the cams.
I am fat more familiar with the 650/750 motors, so that could be why.
Great write up and thanks for taking the time!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • zed1015
29 Sep 2009 01:37
#324565
thankyou
All i used was a hacksaw and a file once i had marked out the shape with a scribe.
  • zed1015
29 Sep 2009 01:42
#324566
You are partly correct.
On the 650/750 motors they run a shell bearing crank which needs the high oil pressure hence the restrictors but the 900/1000/1100 motors run roller bearing cranks which get away with only 3psi approx when fully warmed up so they have no restrictors in the cam oil feed..
  • darmahsd
  • darmahsd's Avatar
29 Sep 2009 18:01
#324679
zed1015 wrote:
And here is my finished oiling setup.
I made some billet oil cooler take offs and inserted an alloy splitter block on the return side so that the head gets cooled oil.
The hose is Earls dash 6 which has a 5mm bore with banjo's specified to take a 10mm bolt.
The banjo bolts have been made by myself using 10mm allen bolts and have been bored 5mm.
I've run this set up for 10 years now on a couple of my zeds with no problems at all.
Hope this thread is of some help ?
Nice work, Zed1015 and thanks for the post. I would like to do this to my GPZ1100 next time the head is off. On that bike, there is a factory oil cooler take off where your billet one is. Have you done one to a GPZ where you might make a series of T fittings to get your new oil lines to the head or did you just use a similar billet one? It looks like from the photo, I see a hose clamp for one of the cooler lines. I would like to keep the original crimped lines that go into the takeoff junction for the GPZ cooler. 'Got a better photo of your billet cooler junction where the left hand side can be seen?
Thanks, Stephen
  • zed1015
30 Sep 2009 08:48
#324762
Here's a pic of the other side. On this engine i made a two piece fitting as it was easier than adapting the std oil pressure switch although i then had to fit a pressure gauge on the main oil gallery as i didn't make provision for the oil pressure switch. Previously i have used aftermarket oilcooler take offs that kept the pressure switch and plumbed in the splitter block on the return line.
On the gpz you might be able to use some 'T' pieces as you say or maybe an easier option would be to make a fitting that screws (m14 x 1.5mm) in to the end of the main oil gallery (where the factory test gauge screws in) just above and behind the ignition housing and take the oil lines from there.
  • School Teacher
  • School Teacher's Avatar
30 Sep 2009 10:40
#324783
Good idea!
Also do you do this to both sides of the head? If so i don't see the line going to the other side.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • Tommotbird
  • Tommotbird's Avatar
30 Sep 2009 11:00
#324785
Hi Z1015
I live in Brighton in the UK and just wondered whether you would be up for doing this mod on my Z1100 which has fuel injection fitted. I have an oil cooler that I want to fit too.
Some time over the winter would be great if you have any time- I do have van transport to ship the whole bike if that is easier.
Whereabouts in the UK are you?
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
