How to dry block your kz900/1000.
Re: How to dry block your kz900/1000.
07 Aug 2010 08:45
#388918
Might find this interesting.
Click here > kzrider.com/index.php?option=com_kunena&...w&catid=11&id=150446
Good Fortune! :)
  • zed1015
  • zed1015's Avatar Topic Author
07 Aug 2010 13:56
#388994
ace wrote:
that really is awesome work btw are kzs popular in jolly old england ?? old trumpets(triumphs) & beezas(bsa)& nortons are well respected here in the states!!!!! also would one NEED an oil cooler with your setup ???
Kz's are very popular over here which is unfortunate as it makes it harder and more expensive for me to get parts :) .
You don't NEED an oil cooler especially if running a stock block but i would defo have one if running a big block as they need all the cooling help they can get.
BTW here's a pic of my latest ZED project with BIG BLOCK etc.
  • zed1015
07 Aug 2010 13:58
#388995
And here's what's gonna join it all together.
  • zed1015
07 Aug 2010 14:10 - 07 Aug 2010 14:14
#388997
79MKII wrote:
I am still VERY interested in having this done to my head this fall. Does anyone know of a person that can do this work in the States?
I checked with Ward Performance about their top end oiler kits that they sell for the Suzuki's and for the Vortex heads and they told me that the stock Kaw head casting is too thin to run a top end oiler kit. I was really hoping they would at least do the machining if not sell a whole kit too. I think the castings are plenty thick since we have people on here that have done it and tested it for years with no issues.
Yes! There's lots of meat on the kwak head .
I've done loads of these now with no problems.
All the mods pictured on this thread were done at home with nothing more than a pillar drill and some patience.
And here's a cylinder head i've just twin plugged on the same drill . EASY ;)
Last edit: 07 Aug 2010 14:14 by zed1015.
  • zed1015
07 Aug 2010 14:19
#389000
2.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
07 Aug 2010 14:43
#389008
Wow, you are really handy with home tools! Great work. Is a "pillar drill" what we would call a "drill press" here?
I was wondering how you'd hook up an oil cooler with the dry block mod since those connections are now feeding your top end. Have you done an oil cooler with the top end oiling kit?
The Kaw List:
  • zed1015
07 Aug 2010 17:33
#389062
Yes. We also call it a drill press too.
All my own engines i have modded have an oil cooler too.
I just take the cam oil feed lines from a splitter block on the return side of the cooler that goes to the main oil gallery. See pic below.
  • zed1015
07 Aug 2010 17:41
#389064
2.
  • zed1015
07 Aug 2010 17:48
#389066
3.
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
07 Aug 2010 18:12
#389086
I should have noticed the fittings. I've wondered before if the oil cooler would take away pressure from the top end oiler lines - do you think it would? I guess you've run them long enough to know that it works OK anyway.
The Kaw List:
  • zed1015
08 Aug 2010 02:42 - 08 Aug 2010 03:08
#389238
Pressure will just be the same as a stock motor maybe a touch higher as the oil isn't getting as hot and thin since it coming straight from the cooler and not up the hot cylinder block.
I have three zeds now all running fine with this oiling set up,It was a common mod on all old school big blocked Zed drag bikes of the 70's/80's.
Last edit: 08 Aug 2010 03:08 by zed1015.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
09 Aug 2010 12:12
#389626
how about some more pics of that frame?that thing looks pretty stout,who built it what is it?
keep us posted on the new project,i'm sure that it will be top notch.
