So.... I BLEW up my motor.... literally...
31 Aug 2009 12:12 - 31 Aug 2009 12:13 #317929 by Bicycle Lee
Replied by Bicycle Lee on topic So.... I BLEW up my motor.... literally...
#6
1978 KZ1000 police
Last edit: 31 Aug 2009 12:13 by Bicycle Lee.
31 Aug 2009 12:17 #317937 by Bicycle Lee
So it DID indeed spit a shim. #3 intake valve shim is gone. Cams are fried (luckily I still have my stock ones).
Other than that I think everything is still ok.
So what now? Besides cams, valve cover gasket and valve cover of course. New buckets and shims? How do I ensure this never happens again?
Should I take the whole head off or is it safe to assume the rest of the motor is fine?
1978 KZ1000 police
  • kzz1p
  • One Test Is Worth A Thousand Expert Opinions!
31 Aug 2009 12:41 #317944 by kzz1p
Replied by kzz1p on topic So.... I BLEW up my motor.... literally...
Myself, I would pull the head, just to be safe. Check your valve ,valve spring, retainer and bucket. If there is no other damage, to the head? Replace the damaged parts.
Larry would know if web cams are repairable or not? Even with stock cams, rebuild the damage and keep the valves adjusted.
Life will get better, don't shit-can the bike. Now that you have gone this far, learn and move on from this deal.
It is called EXPERIENCE! Experience is the best teacher, but the price is high.
No worries my friend, your damage doesn't look that bad, from the pictures. I saw one spit a shim at 10,000+ rpm's. The shim came out just above the 1 & 2 exhaust ports. It looked like a large bullet hole, in the head.
Put on your happy face and get busy!
31 Aug 2009 13:48 #317957 by chance
Replied by chance on topic So.... I BLEW up my motor.... literally...
. Hello my friend Hello Looks like you lucked out. You worried something fell down in the bottom of motor ?Pull the pan ..Neil Diamond Rules B)
  • larrycavan
  • Visitor
31 Aug 2009 13:50 #317958 by larrycavan
Replied by larrycavan on topic So.... I BLEW up my motor.... literally...
Brendan,
Something ate that lobe away and that's why it spit the shim.
You have grit through the motor now from that lobe. It's got to come out.
Does the bucket spin in the bore?
Is the top end getting oil?
Larry C
  • larrycavan
  • Visitor
31 Aug 2009 13:57 - 31 Aug 2009 14:00 #317959 by larrycavan
I'm wondering what was rubbing on the spots pointed to by the yellow arrows in this photo.
Last edit: 31 Aug 2009 14:00 by larrycavan. Reason: Photo Brightened up
  • larrycavan
  • Visitor
31 Aug 2009 14:01 - 31 Aug 2009 14:02 #317962 by larrycavan
Better photo
Last edit: 31 Aug 2009 14:02 by larrycavan.
  • larrycavan
  • Visitor
31 Aug 2009 14:02 - 31 Aug 2009 14:06 #317963 by larrycavan
Here's the better pic
How much of the shim have you found?
Last edit: 31 Aug 2009 14:06 by larrycavan.
31 Aug 2009 15:26 #317993 by Bicycle Lee
I haven't found any of the shim yet. Only went as far as pulling the valve cover.
1978 KZ1000 police
31 Aug 2009 15:27 #317994 by nads.com
Replied by nads.com on topic So.... I BLEW up my motor.... literally...
looks like the bucket ate the lobe after the shim cam out. Seen this on my own bike from roting the motor forgetting i had no shim in one bucket. Ir maybe I started it can't remember. That cam lobe looks pointy on the tip. That right there seems to be part of the whole deal. My cams are .407 but they don't look like that. Some of the geometry is rather BOOOM!:woohoo:
  • Kawickrice
31 Aug 2009 16:47 #318023 by Kawickrice
Replied by Kawickrice on topic So.... I BLEW up my motor.... literally...
Man that sucks but it is fixable......Looks like its gonna be a "Hot August Night"..... Wait ain't that a Neil Diamond song.......... Sorry I couldn't resist
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
31 Aug 2009 16:47 #318024 by Patton
Replied by Patton on topic So.... I BLEW up my motor.... literally...
Am thinking the original Z1 valve shims had a center dimple which was blamed for shim fracture, which design was replaced early on with a non-dimpled version. Hopefully, an obsolete dimpled shim wasn't the culprit here.
While unlikely in this case, other reasons for shim failure might include weakening from "regrinding" attempts toward reducing shim thickness (which remove the shim's hardened surface treatment), or using shim-stock under the shim, or using the "wrong" shim intended for a different engine.
Good Luck! :)
