So.... I BLEW up my motor.... literally...
- chance
- Life long biker/
30 Aug 2009 17:03 #317687
by chance
Replied by chance on topic So.... I BLEW up my motor.... literally...
You missing any sockets..lol
- keith1
- Thank you received: 2
30 Aug 2009 18:03 #317698
by keith1
Replied by keith1 on topic So.... I BLEW up my motor.... literally...
sorry to hear about this....you have been through a lot with this bike.....from everything i have read and heard,those cams throwing a shim is a freak thing...i ve got 2x cams and have about 800 miles on rebuild and so far so good.....let us know what ya find.....i ve got a valve cover you can have ....its just sitting in garage.....keith...
- TerryK
- Thank you received: 3
30 Aug 2009 18:14 #317700
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic So.... I BLEW up my motor.... literally...
Sorry to hear about your problem. Not much else that could punch a hole that big other than a shim. That cam is toast as well.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
30 Aug 2009 18:43 #317709
by kzz1p
Replied by kzz1p on topic So.... I BLEW up my motor.... literally...
How many times have you checked the valve clearance since the motor was finished.
I have seen other brands of cams (bolt-in's) spit a shim before. The clearance gets to large, and the cam lobe scoops the shim, right out. I have ran up to a .410" lift with the shim on top. I keep the valve clearance on the tighter side. I beleive it's the duration, is the reason. Most cams around 280*-290* have a somewhat pointed nose, then add in the fast valve action. It become a pitching machine!
On new motors, the valve train can shift around alot. That's why it is wise to keep checking them, at frist. That extra, backup valve cover gasket, isn't a waste of money.
Everyone checks their valves on different schedules, I do the frist 30 min., and then on the third day, then once a week until the valve clearance is stable. It's alot of work, I think of it as buying insurance......To protect my investment.
Good luck! Maybe the damage isn't to bad.
- Bicycle Lee
31 Aug 2009 00:29 #317795
by Bicycle Lee
1978 KZ1000 police
Replied by Bicycle Lee on topic So.... I BLEW up my motor.... literally...
yeah, I probably wasn't as diligent with checking valve clearances as I should have been. I have only checked them a couple times since I got the motor running again.
Kinda anxious about getting the cover off tomorrow... I'll post some pics asap...
1978 KZ1000 police
- Old Man Rock
- Thank you received: 225
31 Aug 2009 04:40 - 31 Aug 2009 04:45 #317802
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic So.... I BLEW up my motor.... literally...
We can all sit here and speculate all day long.... Take the cover off and inspect for that's the only way to know for sure...
The following is something to think about, no need to reply on them....
Prior to running this motor, manual rotations no binding or knock sounds in the valve cover correct?
What about the camshaft sprockets, are they adjustable or did you install OEM sprockets?
If adjustable, are you 100% positive the cam degreeing was spot on...
When re-building this motor, had you replaced your timing chain and components (top idler, gears, guides, rubber etc...)
Was head, cam caps, cylinder nuts and bolts torque sequence and torques values spot on....
Wonder if timing top idler gear snapped out or something...
Engine pre-lube used....
Camshafts where definitely installed correctly (not 180 out) I know, I know but we get in a hurry, late at night, tired etc... it happens...
Valve clearances where on the money....
Ignition timing was spot on (not way too advanced).
As much as I hate to say this, if this was my motor, remove and split the cases and inspect if something is missing, came up the timing chain galley and got spit out through the cover... Doubtful yes, impossible no...
Does it suck, yup but it is repairable... We all feel your pain but these are old machines and shit does happen...
Good luck...
OMR
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 31 Aug 2009 04:45 by Old Man Rock.
- BSKZ650
- Thank you received: 14
31 Aug 2009 04:58 - 31 Aug 2009 04:59 #317806
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic So.... I BLEW up my motor.... literally...
the positive thing is it was still running, and well enough to get you home,,
I do agree, look and see what really went wrong, there are way too many parts in the top end that could have caused the problem.
I have seen motors blow that looked like a bomb went off inside them, one of them caused by a loose carb air cleaner stud.
let us know
let us know
Last edit: 31 Aug 2009 04:59 by BSKZ650.
- Bicycle Lee
31 Aug 2009 12:05 #317917
by Bicycle Lee
1978 KZ1000 police
1978 KZ1000 police
- Bicycle Lee
31 Aug 2009 12:07 #317918
by Bicycle Lee
- Bicycle Lee
31 Aug 2009 12:08 #317920
by Bicycle Lee
- Bicycle Lee
31 Aug 2009 12:09 - 31 Aug 2009 12:10 #317922
by Bicycle Lee
1978 KZ1000 police
1978 KZ1000 police
Last edit: 31 Aug 2009 12:10 by Bicycle Lee.
- Bicycle Lee
31 Aug 2009 12:12 #317927
by Bicycle Lee
