- Thank you received: 3
Overheating help
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
i have been trying to make the carbs richer then they should be to help. also i don't really get on it hard too much a stay around 4 to 5k rpm im happy with cruzing at 80mph and 5th gear. the bike is gear'd to the point where it will go 100 in 3rd at about 8.5. i did go a little over board with the cams i know :blush:
It's just the age old saying: You have to give up something, to get something. Your motor is built to run twice as many rpm's, then what you are using it for.
It may run warmer with tall gears (lugging it)
What is the elevation where you live? Flat ground or mountainess? Big city or small?(stop and go/ or more freeway)
What is the timing currently set at?
We call the shots while building them, once running, they call the shots. We are just along, to make them happy!
- Silver Tiger
I been trying to remember what the timing is set too its around 40 degrees as what the manual for the dyna 2000 recommends.
I also do a varying amount of different types of riding i try to get away from the stop and go red light traffic as much as possible but it does happen when i sit in traffic for a long time i turn the motor off.
also i emailed holly twice now no reply about my oil cooler questions i guess im gonna call them monday
I really need to to get a oil cooler my bike is gettign very hot lol
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- kzz1p
Please remember, big bores will run alittle hotter, that is normal. You might try asking LarryC, if the larger valves, cams and carbs can affect motor cooling at lower speeds, due to a slower flow rate.
Sea level is good, for sure!
I'm sorry if I missed it, but did you state what the cam timing is? I guess I am asking, standard, advanced or retarded?
PS- I would use your stock B8ES plug, until you workout your problem.
- kzz1p
Nads had talked about the valve springs getting hot?? I would ask Jay about that, He sells a cam that is very close to what you have. He always says, they are good for a street hotrod. Ask him, that might be one more thing to cross off, your list?
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- KZYoungBlood
1981 KZ1000-J1
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Thank you received: 2098
correct sparkplugs (heat range);
no air leak;
compression not too high;
clutch not slipping;
brakes not dragging;
chain lubed and in good condition;
tires properly inflated;
fresh oil of correct viscosity, at proper level;
oil filter okay, not collasped or clogged;
oil pressure okay;
no fuel contamination of oil in crankcase.
Sorry if overlooked, but what are current spark plug readings? Fuel mixture possibly too lean? Float bowl fuel levels correct? Any signs of pre-detonation (pinging)?
Where satisfied carbs are set up correctly (and also matched to air intake and exhaust), and compression isn't too high, and no abnormal drag in drive train, and other above noted components such as oil, etc. are all okay, seems to me by process of elimination to cast suspicion on ignition timing.
Must ask a dumb question -- With existing Dyna 2000, is it possible to verify timing with a strobe-type timing light, to assure alignment of F mark at idle rpm, and also to assure correct operation (movement) of the mechanical advancer (if still fitted with Dyna 2000)?
Mentioning this because the Dyna-S ignition instructions are confusing (to me at least) when saying to use the advance marks instead of the F mark for timing purposes. With Dyna-S, I successfully use the F mark, same as when timing with points.
I realize the Dyna 2000 is a different animal from the Dyna-S, and later model Dyna 2000 even more so with added sophisticated adjustable advance curves. Sorry I'm not more familar with Dyna 2000. But still wondering if adjustment of it in this case might be root of the current overheating problem (as in too much advance).
Good Luck!
- Silver Tiger
I did lose my baffle the other day and i cant tell what kinda exhaust is on my bike its not a vance and hines or mac don't think its a kerker. i ordered a vance and hines baffle because that's what it had before and this one doesn't fit all the way like the last one did. it runs great with no baffle but loud as all crap. with this baffle its restricting air flow and im not getting as much acceleration. hopefully it isnt making my bike hotter with the air restriction. i plan to change my exhaust out soon with a brand new vance and hines with a competition size baffle i have laying around i got before they stopped making them, but i don't want it to blue and i still don't think i have it rich enough i wish there was a dyno around me now they all went out of business.
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- larrycavan
- Visitor
Don't take this wrong.
Something's not coming together with that combo. You're down at least 15-20 HP from what I would expect from the combo you have.
1075, Web 110 grind, 29 smoothbores, street port cut with stock valves, Yosh pipe. Not fully tuned when this was taken.
Do you have any runs with RPM rather than MPH? What were your A/F readings?
- kaw-62046
