Overheating help
- Silver Tiger
I have a 1974 z1 it has a kz1000 jug 1045 10.25:1, port and polished,over sized valves,36mm mikuni flatslides,dyna 2000 and coils, largest hotstreet web cams sold,taylor wires,ngk iridium plugs standard heat range. completely rebuilt last year
basically i don't know what temperature a kz1000 a should run at. my heat gun reads about 295 to 305 on the head and 240 on the jug, it warms up quickly and stays constant. i tested a friends kz1000 with similar modification and it was running around that as well. ive had my bike dyno'd (if any one wants to read the chart i could post) it is a little rich in bottom end and dead on in the top end, the bike isnt running lean, but after i ride it around for about a hour or so it starts getting hard to shift between gears and doesnt like to idle and the engine feels pretty hot the heat gun still only says around 300. im running 10w40 amsoil in it right now and going to switch to 20w 50 next oil change.
I don't have a oil cooler and id like to install one, but i still don't know what size to put on it and how to run the oil channels. also i know a z1's oil pressure is only like 10 psi so would that be a problem with a oil cooler? ive tested my oil pressure i get about 12 to 15psi around 4000 rpm.
sorry if my text is confusing and thxs for any replys
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- MFolks
- Thank you received: 540
Have you been to www.americamclassix.com or:http://www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
Americanclassix has the fittings you need. You can always find a cooler on ebay and get the lines at any auto parts store. Make sure your timing is spot on. What plugs are you running? Some bikes just run hot-like mine. Putting thicker oil in might not be the answer. I used 20/50 in mine and it made it worse. Last summer I rode up to Canadia and it ran hot and pinged all day. We changed the oil to 10/30 the next day and went on a 6 hours ride and it ran great. Some people say a cooler isn't needed until you get up in the 12000cc range, but I know my bike will benifit from one and it sounds like yours will to.
12000cc range? Dont ya mean 1200cc????? :laugh: :laugh: :laugh: . Just kidding don....
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Old Man Rock
- Thank you received: 225
NOTE: You can order in various line fittings!
The GPS1100 oil cooler are 5-7 row coolers so this will be more than enough. Earls are also available in 7 row....
JCWhiteny also carried Earl coolers... They're not that expensive!
American Classix has the adapters, expensive but well made and being an extremely important component for engine lubrication and cooling...
OMR
www.jcwhitney.com/EARLS-TEMP-A-CURE-OIL-...+600007258_10101.jcw
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
