Overheating help
- Silver Tiger
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- PLUMMEN
- Thank you received: 104
oh my aint that purdy,rest of bike looks pretty nice also! im gonna say as far as your overheating issue id definately run an oil cooler .youve basically got a healthy dragbike motor that would be fine a 1/4 mile at a time with a cool down between passes ,but stop and go traffic with those cams and carbs is going to keep it loaded up causing your overheating issue.heres a pic of that tach u can get a matching speedo too
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- PLUMMEN
- Silver Tiger
i acutally just dropped the slide needle on and made my carbs richer on the mid range runs even better i should have done it sooner.:side:
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
i have a old maxxis on it now. im going to switch to a pirrelli sport demon soon. 130/90 16inch
Adding fuel mixture, cools the motor temp. In my opinion, I would rather be spot on at a idle and a touch, rich wide open. It buys me a safety zone!
You may also try retarding the timing. If you fire the motor at a later time, the motor has a longer cooling peroid.
Gear ratio - Every motor! electric or gas, has a speed that it likes to operate at. At that one speed, everything just clicks, the flow, engine temp, timing, fuel mixture, etc.
The age old trick, is to find that spot?? Gear ratio and riding style, affect engine temp.
Then, if you adjust to the problem and reduce the heat, buy an oil cooler, they look cute.
PS- If you lean the mixture, temp goes up. If you advance the timing, temp goes up. Wrong gearing, temp goes up.
I guess all you can do, is reduce cylinder temp or reduce cylinder pressure.............Take it for what, it's worth!
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- keith1
- Thank you received: 2
are you going by oil temp or head temp?
oil temp
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- davel
ive had my bike dyno'd (if any one wants to read the chart i could post)
By all means. Post it if you've got it. Also the cam grind number and any other performance mods. Thanks
- Silver Tiger
as for cams im pretty sure they are these i forget i threw out the box i do remember they were biggest hotstreet they sold but there web site is a little differn't look'n now
Excellent mid and upper end performance for hot street. Requires High Compression Piston, Shim Under Followers, and Performance Valve Spring Kit. Price Per Set (2).
.435/.435 288°/288° 260°/260° www.webcamshafts.com/pages/motorcycle/ka...ta/tc_1730_2573.html
i also don't remember my valve size here a pic :side:
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Attachment moo.zip not found
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
