Overheating help
  • Silver Tiger
  • Topic Author
08 Jun 2009 21:28 #297582 by Silver Tiger
Overheating help was created by Silver Tiger
I know there are other posts on overheating and oil coolers but i wanted to try to get a more specific answer.
I have a 1974 z1 it has a kz1000 jug 1045 10.25:1, port and polished,over sized valves,36mm mikuni flatslides,dyna 2000 and coils, largest hotstreet web cams sold,taylor wires,ngk iridium plugs standard heat range. completely rebuilt last year
basically i don't know what temperature a kz1000 a should run at. my heat gun reads about 295 to 305 on the head and 240 on the jug, it warms up quickly and stays constant. i tested a friends kz1000 with similar modification and it was running around that as well. ive had my bike dyno'd (if any one wants to read the chart i could post) it is a little rich in bottom end and dead on in the top end, the bike isnt running lean, but after i ride it around for about a hour or so it starts getting hard to shift between gears and doesnt like to idle and the engine feels pretty hot the heat gun still only says around 300. im running 10w40 amsoil in it right now and going to switch to 20w 50 next oil change.
I don't have a oil cooler and id like to install one, but i still don't know what size to put on it and how to run the oil channels. also i know a z1's oil pressure is only like 10 psi so would that be a problem with a oil cooler? ive tested my oil pressure i get about 12 to 15psi around 4000 rpm.
sorry if my text is confusing and thxs for any replys
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
08 Jun 2009 21:39 #297593 by MFolks
Replied by MFolks on topic Overheating help
My 82 GPZ1100 B2 came stock with an oil cooler and the ELR's do too. My engine has about 2.8 PSI oil pressure when fully warm. If you can get a wrecked ELR or a GPZ1100 I'd imagine the lines and oil cooler would almost bolt right up.
Have you been to www.americamclassix.com or:http://www.holley.com/types/Temp-A-Cure%20Oil%20Coolers.asp
  • Silver Tiger
  • Topic Author
08 Jun 2009 21:51 #297600 by Silver Tiger
Replied by Silver Tiger on topic Overheating help
i went to both but i dont know what size holly would fit my bike ever been to pmc's web site there stuff if bad ass but expensive www.excite-webtl.jp/world/english/web/?w...&wb_lp=JAEN&wb_dis=2
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
  • Silver Tiger
  • Topic Author
08 Jun 2009 21:59 #297603 by Silver Tiger
here's a pic of the motor out of the frame
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
  • Silver Tiger
  • Topic Author
08 Jun 2009 22:01 #297604 by Silver Tiger
dang thing wont let me post i swear i re sized it right
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
08 Jun 2009 23:07 #297608 by donthekawguy
Replied by donthekawguy on topic Overheating help
Americanclassix has the fittings you need. You can always find a cooler on ebay and get the lines at any auto parts store. Make sure your timing is spot on. What plugs are you running? Some bikes just run hot-like mine. Putting thicker oil in might not be the answer. I used 20/50 in mine and it made it worse. Last summer I rode up to Canadia and it ran hot and pinged all day. We changed the oil to 10/30 the next day and went on a 6 hours ride and it ran great. Some people say a cooler isn't needed until you get up in the 12000cc range, but I know my bike will benifit from one and it sounds like yours will to.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • oldkaws4ever
  • Have no regrets...... You only live once.
08 Jun 2009 23:14 #297609 by oldkaws4ever
Replied by oldkaws4ever on topic Overheating help
12000cc range? Dont ya mean 1200cc????? :laugh: :laugh: :laugh: . Just kidding don.... B)
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Silver Tiger
  • Topic Author
08 Jun 2009 23:34 #297610 by Silver Tiger
BR8EIX
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
  • Silver Tiger
  • Topic Author
08 Jun 2009 23:38 #297611 by Silver Tiger
im not asking for a handout but i would like it if someone posted some specs on a oil cooler that they mounted on there kz1000 and what problems they encountered ive never done a oil cooler and dont wanna mess up, also do u fill it with oil to prime it when u first install it? :P
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
09 Jun 2009 06:06 - 09 Jun 2009 06:14 #297654 by Old Man Rock
Replied by Old Man Rock on topic Overheating help
Here's the route I'm taking...
NOTE: You can order in various line fittings!
The GPS1100 oil cooler are 5-7 row coolers so this will be more than enough. Earls are also available in 7 row....
JCWhiteny also carried Earl coolers... They're not that expensive!
American Classix has the adapters, expensive but well made and being an extremely important component for engine lubrication and cooling... ;)
OMR
www.jcwhitney.com/EARLS-TEMP-A-CURE-OIL-...+600007258_10101.jcw
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 09 Jun 2009 06:14 by Old Man Rock.
  • Silver Tiger
  • Topic Author
09 Jun 2009 12:07 #297722 by Silver Tiger
thxs man
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
  • Silver Tiger
  • Topic Author
09 Jun 2009 15:45 #297764 by Silver Tiger
i hate to ask but what line fittings do you recommend especially what would fit on the American classix part, like with the stainless steel lines in the picture :huh:
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
