- Thank you received: 11
Overheating help
- tachrev
- Rubber Side Goes Down
- Silver Tiger
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Old Man Rock
- Thank you received: 225
Here's some results of testing I've been doing.... On a triple digit day and in a hearty run oil gets up around 250*F.... :ohmy:
The intake and exhaust port measurements where accomplished with Laser temperature meter so the numbers may be off a little due to aiming... Oil temp was measured with Fluke temperature meter and bead sensor inserted into the engine case.
NOTE: For these measurements, running 20W/50 non synthetic... Once break in period completed going with Mobil 1 15W50 due to recommendations and it has a very good level of ZDDP.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- davel
Also, if you have a chance...It would be interesting to know if the temperature continues to rise if you let the bike idle for 5 - 10 minutes after the 20 mile high speed run.
Good work! Thanks again.
- Old Man Rock
1015cc Wiseco 10.25:1 compression
Webcam .365 lift camshafts @ 283 duration
29mm carbs Keihins
Kerker w/1.5" Baffle
Dyna S EI and Dyna 3 Ohm Coils
"It would be interesting to know if the temperature continues to rise if you let the bike idle for 5 - 10 minutes after the 20 mile high speed run."....
Hmmm, I just didn't think of that... Same time, I never let it idle for any duration as such without a cooling fan on the motor so it would most likely cool down.
From most of the research I can find, thermostat controlled cooler are switching on ~ 180*F so yeah, I'm over that considerably. Especially considering we haven't even reached our HOT time of the year....
And yes I do realize, who in their right mind is going to ride when it's 115*F out.... No joke, July & August here is 110-115....
Kinda sears the nads to the seat..... :blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- davel
I was thinking that the 5 - 10 minute idle time might simulate what would happen in stop and go traffic after a run on the highway.
Anyway, good to have the numbers before installing the cooler. Now you can do a before/after comparison when the cooler is installed and enlighten us.
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Old Man Rock
All in all, first step for me anyways since I'm not using this as an ever day ride, synthetic oil when I hit ~ 1500 miles on the new re-build. Then re-do my temp tests and if still over temp, then Earls oil coolr for sure...
Hell, I just might do this anyways for GPZ1100 air cooled bikes came stock with oil coolers... I think the Kawi team new something thus did this on the newer GPZ....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Now that you have the bigger pistons, 435 cams,36mm carbs, etc., you have a higher rpm setup. Now you are taking this high rpm setup, driving down the street and accross town with it. Can this over heating be, a down side to a modified engine?
Perhaps it will run cooler, when it is in it's favorite operating range? What range was it built to run in ?
Do you need lower gears, so it can rpm a little to hit that range?
- nads.com
- Thank you received: 20
you guys have me worrying about more intense heat then your bikes since my cams are bigger. i just started fiddling around with my accelerator pump on my carb's and my bike is really start'n to haul ass. i wish i had done that a while ago. :side: it seemed to help cool it down a little with more gas being sprayed in once in a while but its probably my imagination
- nads.com
The valve springs are getting hot and the heat isn't leaving the head. Best way to cool down besides a cooler (of beer) is jetting up.Silver Tiger wrote:
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
