- Thank you received: 225
Overheating help
- Old Man Rock
Same time, it's a threaded block so you can always replace with what ever line connector you choose...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Silver Tiger
Bikes Owned
1972 Rickman 250 Montesa
1974 Z1 - Kz1000 Jug 1045cc 10.25:1,Port and polished,Oversized valves,Underbucket shims,36mm Mikuni RS Flatslides,Dyna 2000 and 2.2ohm coils, Webcams 435 @ 288° duration,Taylor wires,NGK iridium plugs
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Old Man Rock
Is this a kit for the KZ900/1000...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- MFolks
- Thank you received: 540
Radio Shack carries a small selection and I believe Mouser and Allied have a large selection.
- Silver Tiger
www.excite-webtl.jp/world/english/web/?w...&wb_lp=JAEN&wb_dis=2
Its where i got my electronic tach that looks like a stock z1 tach should look like a tach up until 81 i think they have a white face model too hold on ill take a pic because that last page where the tach is on there website is down at the moment.
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- keith1
I know there are other posts on overheating and oil coolers but i wanted to try to get a more specific answer.
I have a 1974 z1 it has a kz1000 jug 1045 10.25:1, port and polished,over sized valves,36mm mikuni flatslides,dyna 2000 and coils, largest hotstreet web cams sold,taylor wires,ngk iridium plugs standard heat range. completely rebuilt last year
basically i don't know what temperature a kz1000 a should run at. my heat gun reads about 295 to 305 on the head and 240 on the jug, it warms up quickly and stays constant. i tested a friends kz1000 with similar modification and it was running around that as well. ive had my bike dyno'd (if any one wants to read the chart i could post) it is a little rich in bottom end and dead on in the top end, the bike isnt running lean, but after i ride it around for about a hour or so it starts getting hard to shift between gears and doesnt like to idle and the engine feels pretty hot the heat gun still only says around 300. im running 10w40 amsoil in it right now and going to switch to 20w 50 next oil change.
I don't have a oil cooler and id like to install one, but i still don't know what size to put on it and how to run the oil channels. also i know a z1's oil pressure is only like 10 psi so would that be a problem with a oil cooler? ive tested my oil pressure i get about 12 to 15psi around 4000 rpm.
sorry if my text is confusing and thxs for any replys
just as a reference, my bike runs at 200 after 45 mins of stop and go and cruising mix with slight goodies...i think the 10.5 to 1 is the heat maker...i m running an old school cooler that i think was a popular one back in the day...i saw a new one in the box a ways back on ebay and looking back, i should have grabbed it......i run a temp guage and a pressure guage just to keep tabs.......keith
- keith1
- Silver Tiger
Bikes Owned
1977 KZ650c
1979 KZ650SR
1981 XV750 Virago
1994 XT2
- sabell
'78 KZ1000A2
'79 650SR
