- Thank you received: 20
ANY IDEAS WHY?
- nads.com
- nads.com
- keith1
I just read the rest of your post. Sounds like the timing is way too advanced. If you have it set to fire at the fire mark it is way too advanced. That's why you have to use 93 or whatever. With the piston kit it now has faster flame front and the timing needs to be backed down to increase power and stop the pinging and that god awful vibration through the handle bars. Mark the timing where its at and loosen the screws and turn the plate clockwise one eight of an inch and fire it up. shoud be a world of diff. If its too advanced like I think it is, it should be kicking back on u when u start it. Its running rough simply because it isnt getting enough fuel at idle. That's also the reason it hangs up before it idle back down again. You do not have a vac leak been tested for that. Might have to look into the carbs and double check the idle circuit, pilot jets and needle heights in that order. If it was me i'd check compression before u even go there. Seems odd that it's not popping at all, so this would be the time to tell the truth about that.:lol:
thanks.....i m going to recheck timing one of these nites.......and no, she aint a poppin....
- Thank you received: 2098
Cold compression figures may be good, but marginally too tight valve clearances may cause loss of compression at normal operating temp.
Good Luck!
- TeK9iNe
- What did you do!?!
- Thank you received: 28
It was the bolts that hold the starter clutch assembly to the stator magnet.
The bolts loosened themselves off so far that they were causing the bike to make a klanketing random sound anywhere below 1800rpm, and closer to idle, it would just stall out.
Got some new bolts and lock washers. Proper torque, and problem solved.
Goodluck my friend!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
