- Thank you received: 2
ANY IDEAS WHY?
- keith1
under the tank, so they arent kinked....as soon as i
try to adj idle below 1900 it falls to 1500 then drops like a rock.......i put on reg/rec combo and its putting out like 14.7 at 2k....a little high, but its charging.....how do you test voltage at coils again? i have new accel coils and wires...i was real carefull with cam timing and i would think it would fart and pop if it was off....
like i said everything is sweet except for idle...i dont get.....does anyone else?.....thanks
- PLUMMEN
- Thank you received: 104
- keith1
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- keith1
Not so much the boots to the airbox but also the engine to carb connectors. Carb clean will work too but is more flamable. I use WD40 mostly.
thinking about it more and i tend to lean to air leak also.....i have pods with light k and n oil on them...the carb to engine boots are the ones i got last summer....on beer break now with thinking cap on...:laugh:
- keith1
- anarki650
- Thank you received: 5
I've got my beer hat on too, so my theorizing may be way off base. Just trying to think of anything that might be snagging you up...
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- keith1
Vacuum petcock or not? If vacuum is it feeding at idle right? High idle can be from lean condition. Carbs coming from WG I wouldn't expect that the pilot jets are the wrong size. So, if the petcock isn't flowing right, maybe from the vacuum not activating until you hit some rpms, might not be getting enough fuel, thus lean.
no vac petcock....double outlet pingel vm26carbs with dual fuel inlets...same setup with old top end....she s gettin fuel....thanks.....
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- keith1
I'm guessing WG knew your set up. I'd take off the pods and see how she runs. See if she answers right then.
yes..i filled out a sheet with set up and mods....i dont have stock box.....i just went out and fired it up...fired right up and idled a little lower...
i think at this point, i m gonna take it for a blast this weekend for a shakedown run...top end only has about 30 mins of idle time in garage....
the good thing is i have no leaks and it sounds good....i m 99.9% there....i m sure this is something stupid...just a matter of time.......
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
Sounds too simplistic, but you can eliminate it as a possible cause.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
