Z2 750 crank (Bossie the Kaw)
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: Z2 750 crank (Bossie the Kaw)
12 Apr 2015 05:49
#667608
Steve, I am not taking sides either way. And have no reason to doubt your claim. Only thing is I don't believe you can end up with a 1015 motor. Here is why. Cylindrical volume is V=πr2h (the radius r is squared). So in your case it would be bore for a 1015 motor is 69.4 mm (diameter) which is 3.47 cm radius. And the crank on a Z2 is 58 mm which makes the cylinder volume highiet of 5.8 cm. plug everything you get the following displacement
(pi)*(3.47)sq*(5.8) then times 4 (four cylinders) = 877.60 cc
Smaller than your original 903 cc motor. Now, can the rods from your 903 engine have been used in place of the 750 rods (don't know if that is possible, I have no clue)? In that case, it would have made it a 1015 motor. But like say, I have no doubt you that you are using that crank. Don't have to prove anything to anyone man. So don't get rushed into anything.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
12 Apr 2015 06:16
#667612
It does seem to be a little detuned with the stock 1015 pistons. With the cast or billet pistons, the deck height was even. With the stock ones, it was about 2 mm lower thus lowering compression. All i had then was a German made caliper so I didn't measure it. I now have a digital one and will show the depth with the stock pistons and compare with the 10.25/1 Wiseco's. 58-66 is quite a jump and 8 mm would be hard to miss. If the throws on the crank are shorter, wouldn't the rods be also? I was oblivious to this issue until now. I want to know too. I remember a stamp on the counter balance and the rods have markings as well. It would be helpful to know what the Z2 markings are to compare. If I have to go back to a 903 crank to get the ponies this bike deserves, then so be it. There was interest in this crank for a member's turbo build. We'll see. B)
  • SWest
  • 10 22 2014
12 Apr 2015 07:16
#667624
Just checked eBay for a Z2 crank. Lots of plain bearing KZ 750's and some triple cranks too. No Z2 750 cranks. I don't trust eBay and If I do buy a 903 crank, it will probably be from The Old Kaw Guy. He's always treated me right.
I bought a new throttle cable while there. The one I have is almost two years old.
  • SWest
  • 10 22 2014
12 Apr 2015 07:28
#667626
Bought these in 13 too.
$250 OUCH
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
12 Apr 2015 08:59 - 12 Apr 2015 09:00
#667635
It seems to me that part of the confusion is that overbore piston kits are typically labeled with the resulting displacement, not the piston diameter. Wiseco sells a 1015, 1045, 1075, etc. So it seems perfectly natural to say that you have a "1015 kit" in your engine even if you were using a short stroke crank. We all understand that you wouldn't actually have 1015cc, but it's a very easy way to communicate which pistons you purchased.
I think the idea of running a short stroke crank seems pretty cool, depending on how far into the red you can safely build the valvetrain to go. Modern bike engines are all way oversquare.
The stroke of the Z2 crank has been established, but no one seems to know if the rod length was altered. It seems possible that Kawasaki used the same deck height for both the Z1 and Z2, and just used longer connecting rods to compensate for the shorter stroke length. If that were the case, then a Z2 crank should drop into a Z1 with no changes at all. Does anyone know the rod length, or relative deck height of a Z2 compared to a Z1?
My dad's '74 Z1
'00 ZRX1100
Last edit: 12 Apr 2015 09:00 by DOHC.
  • Tyrell Corp
  • Tyrell Corp's Avatar
12 Apr 2015 10:29 - 12 Apr 2015 10:37
#667647
Yup, also I think just boring out with oversize pistons alone won't make big power gains without more cam and other tuning work. It is more about a motor's valve time area than capacity imo.
Has a 'bored and stroked' under square motor been done before on a zed?
Last edit: 12 Apr 2015 10:37 by Tyrell Corp.
  • PLUMMEN
  • PLUMMEN's Avatar
12 Apr 2015 10:31
#667648
etbike3135 wrote: hows that 4 valve piston working in your motor?
Im wondering what kind of camshafts you use with 1 4 valve piston.
  • PLUMMEN
  • PLUMMEN's Avatar
12 Apr 2015 10:34
#667649
Tyrell Corp wrote: I think the idea of running a short stroke crank seems pretty cool, depending on how far into the red you can safely build the valvetrain to go. Modern bike engines are all way oversquare.
Yup, also I think just boring out with oversize pistons alone won't make big power gains without more cam and other tuning work. It is more about a motor's breathing than capacity.
If you could find pistons with the right pin location it would probably be a riot to ride in a light bike. ;)
  • Tyrell Corp
12 Apr 2015 10:49 - 12 Apr 2015 10:55
#667650
Yes, this is possible, using a short stroke z400J crank with a wiseco "610cc " kit bored out 550 block, same pin size. The rods and forged one piece crank are bulletproof but I think there are factors limiting rpm on any 8 valve ,
Short stroke would lose some bottom end tourque, something the big old kz were good at, the later GPz more power but a lot more 'cammy'.
Good luck on the build Steve, you have most of the bits and the vision for something really nice there.
Last edit: 12 Apr 2015 10:55 by Tyrell Corp.
  • PLUMMEN
  • PLUMMEN's Avatar
12 Apr 2015 10:58
#667652
Its like a 396/427 chevy versus a 454 chevy.The 427 and 454 have the same bore,but the 427 uses the same stroke as 366/396 which makes it a real riot to drive . :woohoo:
  • KZB2 650
  • KZB2 650's Avatar
12 Apr 2015 11:04
#667653
PLUMMEN wrote: Its like a 396/427 chevy versus a 454 chevy.The 427 and 454 have the same bore,but the 427 uses the same stroke as 366/396 which makes it a real riot to drive . :woohoo:
Was thinking the same thing ..... the 383 Chevy and the 302 Z28 motor too. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: PLUMMEN, SWest
  • SWest
  • 10 22 2014
12 Apr 2015 12:49
#667661
You've got to be kidding. The 4 valve piston was Z1E's fault. Like I said, it set me back two weeks. They didn't have just one piston to send me like now. It will cost me $125 for a new piston, figure in gaskets and we're looking at $200. As it is, I'm burning up rear tires. Makes it tough to save the money and keep up with what the bike needs normally.
I'll do it.
