Z2 750 crank (Bossie the Kaw)
  • scubaanders
  • scubaanders's Avatar
Re: Z2 750 crank (Bossie the Kaw)
02 Apr 2017 09:38
#758347
Nice to see the old lady up an running again, and you sure live up to your own saying.
-Ride the piss out of it!
:woohoo: :woohoo:
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
02 Apr 2017 09:41
#758350
We'll see how she does on this trip.
TTYL
  • SWest
  • 10 22 2014
05 Apr 2017 19:03
#758582
Starter was dragging on the trip.
  • SWest
  • 10 22 2014
05 Apr 2017 21:03 - 05 Apr 2017 21:03
#758590
40 year old rubber parts just don't work.
Last edit: 05 Apr 2017 21:03 by SWest.
  • SWest
  • 10 22 2014
06 Apr 2017 20:32
#758678
Back together again.
  • SWest
  • 10 22 2014
07 Apr 2017 19:33 - 07 Apr 2017 19:34
#758750
One thing about it, it slowed my progress.:whistle:
Last edit: 07 Apr 2017 19:34 by SWest.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
08 Apr 2017 06:34
#758770
Hi SWest,
You've probably already thought of this but...
As you demonstrate, the key is a nice interference fit in the crank. Have you checked for taper; that is, are the sides of the key parallel to each other?
As sloppy as that rotor assembly is, we'd also be checking the width of the slot in the rotor itself to make sure it isn't wider than spec, either at a location where the key has never been in contact while in service or, using the width of the slot in a known-good rotor as a baseline.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • SWest
  • 10 22 2014
08 Apr 2017 07:49
#758774
Using the 750 crank to workup the key. The old rotor is just for that. The key fits both ends. The true test will be on the bike in a few. I STILL can't find the other one. :angry:
Only $.50 but it PISSES ME OFF. Gremlins?
  • slmjim+Z1BEBE
08 Apr 2017 09:15
#758785
SWest wrote: ... STILL can't find the other one...
Hate it when that happens.
slmjim was a copier Tech in a previous life. Some of the screws in copiers are quite small. If a screw was dropped in a customer's office the drill was to get on hands and knees, then place a cheekbone on the floor so as to get a sight line as close to parallel to floor level as possible. Maybe use a flashlight lying on the floor too, beam parallel & level, illuminating a long, narrow distance of the surface. Anything lying on the floor that is of any reasonable thickness will be very apparent. Sometimes the item could be found just by the long shadow it cast in the flashlight beam. Might be worth a try...
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
  • SWest
  • 10 22 2014
08 Apr 2017 20:07
#758808
Back into it again.
  • SWest
  • 10 22 2014
09 Apr 2017 06:15 - 09 Apr 2017 06:28
#758823
This is getting NUTS.
Last edit: 09 Apr 2017 06:28 by SWest.
  • SWest
  • 10 22 2014
11 Apr 2017 18:50
#758987
Spent time on my back.:blink: It was worth it.B)
