Katit's 1978 KZ650 project
  • katit
  • katit's Avatar Topic Author
Re: Katit's 1978 KZ650 project
09 Aug 2022 08:24
#871921
There is arrows on mine, pointing forward I assume :)
  • hardrockminer
  • hardrockminer's Avatar
  • Away
09 Aug 2022 19:32
#871950
Sorry to say hardrockminer but this screen shot was taken from the first 1976 service manual.
Some confusion here.  Z1 and KZ1000 use the same caps.  My Z1 doesn't have arrows.  My KZ1000 does.  Should I post photos?
  • Mikaw
  • Mikaw's Avatar
09 Aug 2022 19:45
#871952
HRM, the axle caps are different. Z1 uses 44063-003. The kz900/1000 use 44063-014.
  • hardrockminer
  • Away
10 Aug 2022 06:12 - 10 Aug 2022 06:43
#871965
Interesting....I'm pretty sure I used a set of Z1 caps on my rebuild.  Which is why I commented on the lack of letters, thinking others have probably done the same.  I'm currently on vacation but will check when I get back home.  I think the front wheel on a 650 is the same as a 77 KZ1000.
Last edit: 10 Aug 2022 06:43 by hardrockminer.
  • katit
12 Aug 2022 07:51
#872106
Process. Brake calipers assembled, ready to install.
Bought engine hoist, unfortunately I didn't find any better way to get engine out of a bench. I am planning to lay it on a side and put frame over it. Sounds like it's a best way to approach.
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
13 Aug 2022 13:28
#872167
Yes I did it that way last winter whit my Z1B. My son and à friend helped me and the job was done in about ten minutes, and no scratches.
  • katit
13 Aug 2022 17:33
#872182
Aaand done. Since nothing was really assembled, I quickly got back to frame. Layed engine on side, prepped hardware. Wife with daughter held frame over and I got it positioned. Then I put it upright, used engine hoist once again to lift by the frame and got rear wheel and forks installed. Back on a lift!! They only "gotcha" - got those wire clamps bent, They probably wasn't correctly installed.
The following user(s) said Thank You: Nessism, Scirocco, Wookie58
  • katit
18 Aug 2022 08:28
#872428
Finished painting all plastics, some before/after
P.S. Ordered those stupid rubber washers for forks, still not shipped and it really holding me from getting front end assembly going
  • katit
30 Aug 2022 07:37
#873088
Need some help here. What are those brackets for? Mount behind rear footpegs. There is no positive stop/orientation on how they should be. Is it for exhaust?
I get it I need left one for center stand bump stop. What about right one? I am going to use Delkevich 4-1 exhaust
  • Warren3200gt
  • Warren3200gt's Avatar
30 Aug 2022 08:46
#873090
Yes, exhaust mount hanger brackets for standard 4 into 2 exhaust. The delkevic 4 into 1 comes with a mount bracket that has a center stand rubber stop on it.
Those oem brackets are quite hard to come by and people restoring to standard pay decent money for them here in the uk.
  • katit
30 Aug 2022 08:59 - 30 Aug 2022 08:59
#873091
Thank you! Good to know. Since it's "loose" assembly I will leave them on until  get to installing exhaust. One on a right is damaged, specifically clip on a left which retains thin nut. Left one is perfect.
Last edit: 30 Aug 2022 08:59 by katit.
  • Gdailey2112
  • Gdailey2112's Avatar
  • 82 KZ1100D1
06 Sep 2022 11:08
#873458
Blocking the smog ports is pretty easy.  Here is what I used on my KZ750 head.  I used a NPT tap and plug.  It took a few tries to get the depth right for the tapered threads so the plug ended up flush or just below.  I ended up grinding a chamfer on the outer top edge of the plug to help, since it is at an angle to the surface it threads into.
what size tap and plug did u use?
1982 KZ1100D1
