Katit's 1978 KZ650 project
  • katit
  • katit's Avatar Topic Author
Re: Katit's 1978 KZ650 project
26 Jul 2022 18:27 - 26 Jul 2022 18:29
#871092
All plating done! Now to assembly. Was waiting for wheel locks to plate, now I was able to mount tire. It is PITA, but wasn't bad, really. I guess I am getting good at it. Even with wheel locks it was fine. Of course I first forgot to put rim tape, good thing I realized it before putting other side of tire in. Then, I forgot to make holes in rim tape (heated bolt with a torch and melted them through). Then I put valve stem into wrong hole. Anyhow, som busted knuckles and it's done. No pinched tubes :)
Next will be roller. I want this thing to be move-able. At what point is it easiest to put motor in? Should I do it while I have just a frame?
Last edit: 26 Jul 2022 18:29 by katit.
  • katit
27 Jul 2022 09:31
#871125
Any advice on that? I figured I will need some help, but what is the best time for engine to go in?
  • katit
07 Aug 2022 16:21
#871841
Some more progress. Rear wheel installed, I didn't torque anything yet (where I may take it apart again)
Front end - assembly in progress. All nice chrome, bolts, chased/cleaned threads. Coming together nicely so far (questions in separate topic on triple tree). Roller will be ready soon!
  • Mikaw
  • Mikaw's Avatar
07 Aug 2022 16:33
#871845
Looks great. The wear pointer is on the wrong end of the range. It needs to be near the “e” of range.
  • katit
07 Aug 2022 16:36
#871846
 Will move it! :) Just put it on so I don't lose it. Btw - bought 1/4 piece of black felt to make that dust seal behind pointer.
  • katit
08 Aug 2022 18:17
#871900
Looking like a roller. Just loosely assembled, but it's portable now. Ready for engine.
Brakes assembly in progress
  • Mikaw
  • Mikaw's Avatar
08 Aug 2022 18:31
#871902
It’s a roller! Not picking but want you to be safe, and maybe this is just your “assembled loosely” but your front axle clamp are not correct. The front nut gets tighten first, then the rear leaving the gap in the rear.
  • katit
08 Aug 2022 19:05
#871903
Hey! I appreciate it. Also it is loose assembly- I want to know about things.
when I do final - I read book for torque values so it probably will be mentioned there. But anyways- reason for posting all the pictures is so people see and perhaps notice stuff.
on brake disks I did final torque on bolts but didn’t bend those lock washers just in case..
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
08 Aug 2022 23:52
#871908
The bike is looking really good Katit, you have done a great job over a short time scale
The following user(s) said Thank You: katit
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Aug 2022 02:45
#871911
As Mikaw mentioned, the axle clamp has a arrow mark that has to be pointed into the driving dircetion.
  • hardrockminer
  • hardrockminer's Avatar
09 Aug 2022 05:25
#871917
Newer models have the arrow.  Older ones don't.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
09 Aug 2022 05:52
#871918
Sorry to say hardrockminer but this screen shot was taken from the first 1976 service manual.
