Saving a '81 KZ750-E
- Skidmark
Re: Saving a '81 KZ750-E
16 Aug 2020 15:24Nessism wrote:
You can use a file after painting the black. That's what I did. No clear. The exposed polished areas will tarnish with time but I'm not a fan of rattle can clear (even less so than rattle can black.)
I have read good reviews of the PJ1 Fast Black. I am hoping it lives up to it's reputation.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
16 Aug 2020 22:02Mikaw wrote:Skidmark wrote:calum wrote: I put clear on mine, but it was 2K clear engine paint through a gun.
I tried looking for quarts or liquid, not aerosol.
I do not believe 2K Clear is available in the US - EU countries cannot ship it here.
It’s available at painters supply in the states. not sure if this one is high heat but they carry 2K
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
17 Aug 2020 11:54
I had thought the ultrasonic cleaning on the cylinder head had just left some of the OG paint behind... now that masking for paint is nearing completion I began doing a really thorough inspection. Old oil and road bits were congealed on top of the head between the fins. A lot of pick work, to be followed up with brake cleaner (carb cleaner doesn't cut it). Yeah, no one will see it, but I will! This thing will be clean. Surface prep means everything to paint adhesion.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
17 Aug 2020 14:39 - 17 Aug 2020 14:39
While cleaning up the residue left on the cylinder head, I cleaned up the threads in the head for the valve cover using a tap. I was extremely careful cleaning the threads out afterward. I also picked up a thread chasing die to repair some of the bolts. Even though these will not be used during final assembly (only for painting), I didn't want them to mess up the inside threads again. All bolts had the threads cleaned on the wire wheel, then chased with the die. With all that said, the valve cover is on for the last time and ready for paint. I had to order another set of urethane masking plugs to protect the balance of threaded holes, so I have to wait for those to arrive before I can begin the paint process. Small steps... but needed.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 17 Aug 2020 14:39 by Skidmark.
- gazzz
18 Aug 2020 13:04
I could only recommend making degreasing before glass beads blasting. Glass beads blasting blow dry dirt pretty well but it is mostly useless against grease. In fact the process of preparing parts for glass beads blasting takes much more time then blasting itself. I use degreasing (engine cleaning) gun filled with gasoline, carburetor cleaner, lot of different brushes (including small brass wire brushes and toothbrushes ) and scotchbrite-on-a-sticks to remove as much of dirt and grease as possible before glass beads blasting. For KZ650 cylinders it took two days of cleaning and preparations (covering) followed by only 20 minutes of glass bead blasting to get cylinder ready for painting, without any spot of dirt on them
Kawasaki KZ650 cafe-racer: in progress
Kawasaki Zephyr 750 (810ccm, 4in4, spoked wheels)
Honda CB815 "Eight Fifteen" cafe-racer
Yamaha XJ "Eight Ball" cafe-racer
www.gazzz-garage.com
- Skidmark
18 Aug 2020 13:24
All of the grease was off the bottom end before bead blast. This junk is coming off the head. The cylinder head was never put in the bead blast.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- gazzz
19 Aug 2020 13:21
Whoops, sorry, I only recently finished my cylinders (bored, honed, upper surface planned, then cleaned, blasted and painted) so seems I've been carried away and somehow decided you have an issues after blasting.
- Skidmark
19 Aug 2020 15:48
It's all good, Gazzz... I always look at your quality and craftsmanship and just hope I can get there someday! With so many details to work through it's easy to miss one and have to back track.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Aug 2020 14:47
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Aug 2020 14:49
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Aug 2020 14:51
The reason some areas appear glossier than others is I just couldn't wait to take some pics!!! :laugh: Those areas are still wet while the others are drier.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Aug 2020 14:54
One aerosol can almost covered the entire engine with a light coat. I am planning on three coats of black, with the remainder of the fourth can left for touch up and stand mounting points.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
