Saving a '81 KZ750-E
- Skidmark
Re: Saving a '81 KZ750-E
08 Aug 2020 14:38
A bit more cleaning and I can start the masking on all the mating surfaces.
The block and head hve been at this point for quite a while, now.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
09 Aug 2020 14:44
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
09 Aug 2020 15:21
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
10 Aug 2020 14:34 - 10 Aug 2020 14:37
The top end is almost sealed. All of the side/case covers require cleaning before they get put on. Still need to cap off the valve cover vents, intake/exhaust ports.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 10 Aug 2020 14:37 by Skidmark.
- Skidmark
10 Aug 2020 14:54
I am using all of the old hardware and studs at this point. Final assembly will with APE studs and stainless case screws.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
10 Aug 2020 16:18
Looking good!
What are you going to paint with? I used VHT and regret it. Wish I knew what kind of paint Kawasaki used. That stuff was tough!
10 Aug 2020 16:30Nessism wrote: Looking good!
Agree, KHI paint shrugged off the Paint stripper didn’t it.
- Skidmark
10 Aug 2020 16:35 - 10 Aug 2020 16:42
I am going to use PJ1 engine and case paint (rattle can). I have not found a heat resistant semigloss clear yet. They have the good stuff in the EU, but they are not allowed to ship it to the US. Since I plan on exposing the aluminum (fins, text, cam cover ends) I wanted to put a couple coats of clear on it.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 10 Aug 2020 16:42 by Skidmark.
10 Aug 2020 17:20
- Skidmark
11 Aug 2020 17:19
Cleaning all the gasket surfaces is getting very time consuming. The final assembly will go quicker than this, I bet! Slowly getting closer to trying to lift this thing into my blast cabinet. I hope I have enough room to move the gun around with it in there...
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
11 Aug 2020 18:17
Go buy an old lazy Susan from Salvation Army so you can spin it in your cabinet
- Skidmark
11 Aug 2020 18:35 - 11 Aug 2020 18:37
You can see the blast cabinet against the wall. I think it will be too tight a fit to spin around in there! Good idea, though. I will need to put it in and take it out for repositioning several times. It's not the biggest cabinet, for sure.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 11 Aug 2020 18:37 by Skidmark.
