Saving a '81 KZ750-E
- Skidmark
Re: Saving a '81 KZ750-E
17 Sep 2020 18:33
I finally got the last of the o-rings and seals that I need ordered. I am relatively confident that I have all of the gaskets, seals, and o-rings either here or on the way now. I even picked up a tube of Kawabond 5 gasket sealer. I should be able to get the bottom end done and into the frame after this latest order gets here. :woohoo:
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
17 Sep 2020 20:06
Keep chipping away. Looking forward to seeing the completed engine.
- Skidmark
17 Sep 2020 21:46
One of the things I need to start the top end (when I get there!) Is ring compressors. Not going to attempt hose clamps... just sayin'! Something I need to start thinking about.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- M_a_t_t
17 Sep 2020 22:49
You can rent them from your LAPS if you don't want to buy them.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- Skidmark
18 Sep 2020 08:01
A man cannot have too many tools...
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
20 Sep 2020 17:24
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
20 Sep 2020 17:34
The 6 mm lower case bolts should be torqued to 87 in/lb, according to the shop manual. I verified the torque setting several times, but my torque wrench isn't clicking. I am at a tension that I do not feel comfortable going beyond, for fear of damaging case threads. It may be time for a new torque wrench. Cheaper than messing up the case threads!
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- KZJOE900
- Administrator
Super Users
20 Sep 2020 18:45 - 20 Sep 2020 18:45
One hundred percent agree with you. Nothing will ruin your day more than a stripping a bolt. Your patience will pay off. Even 87 in/lb seems high for a 6 mm. The 6 mm bolts for my 900 take 69 in/lb. What shop manual are you using? I would only trust the factory service manual. I have run into some wrong torque specs with my Clymer shop manual. Would have stripped some cam bolts if I would have used the recommendation in the Clymer on my bike.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 20 Sep 2020 18:45 by KZJOE900.
- Skidmark
20 Sep 2020 19:41
I am using the factory shop manual. But my gut is telling me to stop.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
20 Sep 2020 20:00
You're gut is right. Allow your judgement to override the stupid wrench. Way too many threads are pulled out from guys blindly following some torque value in the manual when it's not critical.
20 Sep 2020 20:24
FSM states a 6mm bolt should have 54 to 78 Inch pounds
- Skidmark
20 Sep 2020 22:30
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
