Saving a '81 KZ750-E
  • 750 R1
  • 750 R1's Avatar
Re: Saving a '81 KZ750-E
21 Oct 2021 18:47
#856897
With the length of the hose you have I doubt you'll have any trouble with oil grips, unless your motor is stuffed....    Due to the length of hose, and the up hill trajectory from the crank case, you should be fine...
  • Skidmark
  • Skidmark's Avatar Topic Author
22 Oct 2021 08:25
#856922
I saw this on Facebook and it cracked me up!  Thought I would share...
Retired gearhead
'81 KZ-750 E2
  • 750 R1
  • 750 R1's Avatar
22 Oct 2021 15:43
#856930
He stole that name, this is the original, This was build at least 10 years ago or more .....
  • Skidmark
22 Oct 2021 18:27
#856938
Nice!  Interesting having the frame painted white.  A lot of detail on that machine.  Just goes to show you that you never know where the stuff comes from on the interwebs.
Retired gearhead
'81 KZ-750 E2
  • 750 R1
  • 750 R1's Avatar
23 Oct 2021 04:05
#856943
If my memory serves me well , I think they used a GSXR400 frame with the 750 KH triple, it was around 300 pounds and 130HP, it sure would have been a fun ride..!!
The following user(s) said Thank You: Scirocco
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Oct 2021 05:21
#856944
Some details to the triple Kawasaki..
The following user(s) said Thank You: DOHC, Skidmark
  • Mikaw
  • Mikaw's Avatar
23 Oct 2021 11:21
#856953
There’s a bike in that picture??? Where
  • Skidmark
31 Oct 2021 14:39
#857233
Four thermal cycles on the motor now,  and the drain plug is dripping.  I know I put a new washer under the drain plug. I tried tightening it a little more and cleaning it, but still a very slow drip.  I don't want to over tighten it.  Oh well, new one ordered (made sure it was genuine OEM part).  My DMV appointment is this Thursday, so hopefully I come home with a new title and license plate.  It has warmed up again after a couple week cold snap and a bomb cyclone.  3.5" of rain in 48 hours.  Thankful for the moisture, but it's all or nothing.  That storm raised the Lake Tahoe level by 6"!!!  Mind boggling amount of water for a lake that size.  I just may be able to get this motor broken in before the temps drop below my comfort zone after all.  I would like to have 500 miles on it before it gets parked for the winter.
Retired gearhead
'81 KZ-750 E2
  • Skidmark
04 Nov 2021 17:57
#857417
After 3-1/2 years of possession, this bike it legally mine and tagged for the street!  Just in time for the temps to drop.  This is the first time I have owned a registered and insured street bike since 1992.  Last street bike I sold was a Yamaha FZR1000.
Retired gearhead
'81 KZ-750 E2
The following user(s) said Thank You: Nessism, calum
  • Mikaw
  • Mikaw's Avatar
04 Nov 2021 18:24
#857418
Congratulations. As Steve would say. NOW GO RIDE THE PISS OUT OF IT!
The following user(s) said Thank You: Nessism, Skidmark
  • 750 R1
  • 750 R1's Avatar
04 Nov 2021 18:33
#857419
Well done mate.. !!   Watch everyone and ride safe....
  • Nessism
  • Nessism's Avatar
04 Nov 2021 18:55
#857420
Four thermal cycles on the motor now...
Have you torqued the head again?  Best to do so until you confirm there is no torque fall off.  Back nuts off until they move and then immediately reverse direction and tighten.  I say this as someone that used cheap gaskets one time and found the torque kept falling off with each heat cycle.  Kawasaki doesn't specifically call out retorquing the head in the maintenance schedule but I think they should if you want to assure a well sealed engine.
The following user(s) said Thank You: ThatGPzGuy, Skidmark
