Saving a '81 KZ750-E
- Dr. Gamma
Re: Saving a '81 KZ750-E
20 Sep 2021 15:30 - 20 Sep 2021 15:34
My Ohlins damper did the same thing. I just placed a thick o-ring between the the Ohlins damper bracket with the heim joint to where it mounted to my fairing bracket.
The o-ring limited how much the damper could move back and forth or side to side!!!
1986 RG500G 2 stroke terror.
Last edit: 20 Sep 2021 15:34 by Dr. Gamma.
- Skidmark
20 Sep 2021 16:16
Two flat washers and some sections of fuel line cut to fit and all is good. Had just enough thread length for the washers and rubber.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
20 Sep 2021 18:02
I used a steel tube as a spacer, and used an existing hole in the frame. Once it is off the lift, I will adjust the rotation of the fork clamp.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Sep 2021 13:30
I made two new hinge pins for the seat using 6mm round bar, 18-8 stainless steel.
I tested the horn, and it is dead. Loosened and tightened the adjustment screw with 12v applied, and nothing. Looks like I need to source a horn now.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
21 Sep 2021 15:46
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
The following user(s) said Thank You: KZJOE900, Scirocco, gazzz
- DoctoRot
21 Sep 2021 17:53
Really nice. Great job!
- scubaanders
21 Sep 2021 22:05
Absolutely stunning Steve!
//Anders
//Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- 750 R1
- Daftrusty
23 Sep 2021 07:00
All your hard work was definitely worth it.
It’s absolutely beautiful!
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
- Skidmark
23 Sep 2021 10:55 - 23 Sep 2021 11:32
I couldn't help myself and rode it up and down my street yesterday. Discovered a small oil leak that needs to be addressed. I need to change the o-ring and oil seal at the tachometer drive. I must have missed replacing those when I did the head.
Minor stuff here and there to do still. I better get off my butt and get the registration paperwork going. I have to send a registered letter to show an attempt to contact two people that are on the title with the original owner (who gave me the bike). He had a couple he knew as co-signers on the original loan. He paid it off decades ago, but was lazy and never got their names removed from the title. The couple is now divorced, and have both moved away. He has lost touch with both for a long time now. Once I get a non-deliverable receipt from the post office, I can use that to transfer the title with only his signature. I should have done this a couple years ago, but since the bike was getting torn all the way down is wasn't a priority for me. Before I take this machine out for a more serious ride/distance, I need to get it legal. Hopefully I can get the paperwork straightened out by the time I get the rear shocks, o-ring, and seal.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
Last edit: 23 Sep 2021 11:32 by Skidmark.
- Skidmark
23 Sep 2021 12:24
I am having an issue with my "Chinese" GPS speedometer. I must have missed this on the one page instruction that came with it, but it appears the power wire should only be connected to 9 volts. (see picture) The odometer LCD is only displaying the number 19. No error code, just 19. I only rode the bike a little over 1/2 mile yesterday, so the bike (and gauge) have not moved 19 miles. Assuming the voltage may be the culprit, how would I be able to reduce the voltage from 12v to no more than 9v? I am certainly no electrical wizard. The speedometer needle seems to be functioning properly on the short test ride. Unfortunately there is no customer support considering the gauge's origin.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
