Saving a '81 KZ750-E
- krazee1
Re: Saving a '81 KZ750-E
07 Aug 2021 18:17
Congratulations! You did a wonderful job of restoring and sharing your progress and "learning experiences" along the way!
You saved one that many would have walked away from and built a bike that makes many envious.(myself included!)
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- Skidmark
07 Aug 2021 20:22
I used google and found the camera setting that was reversing the images and video. Learn something new every day.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- 750 R1
08 Aug 2021 15:54If its any consolation, it looked great in reverse...!!!
- calum
11 Aug 2021 03:27
Nice one
I was really happy to browse through this thread today and see that you got her running. A long road but well worth it!
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
- Skidmark
24 Aug 2021 12:59
Spent the last several weeks trying to finish up the wiring and hand controls. I posted more details in the electrical forum. I am stuck. I cut my hair short so I couldn't pull any more out. Trying to wire up repop hand controls for a '73 - '77 Z1/KZ900 into an '81 KZ750e2 harness. I cannot get the turn signals or horn to work.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
24 Aug 2021 16:11
Are you sure the horn works?
25 Aug 2021 06:08
Are you sure the turn signal flasher works?
- Skidmark
25 Aug 2021 14:55
Is there a test with a volt/ohm meter to ensure it is functional, or replacing it is the only way? The factory wiring diagram does not show the internal circuits for both the hazard flasher and the turn signal flasher.
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
- Skidmark
25 Aug 2021 14:56I have not tested it, no. Everything was operational when it was parked. So the functionality of the horn was an assumption on my part.Are you sure the horn works?
Retired gearhead
'81 KZ-750 E2
'81 KZ-750 E2
25 Aug 2021 15:15Not that I know of. You could probe the connectors on the power side of the relay to see if battery voltage is getting to the relay and if it is also exiting the relay. The key will need to be on and the flasher switch engaged. The volt meter will need to be grounded to the frame or engine.Is there a test with a volt/ohm meter to ensure it is functional, or replacing it is the only way? The factory wiring diagram does not show the internal circuits for both the hazard flasher and the turn signal flasher.
The relay needs to see a certain amount of resistance on the other side, but if you are using factory style bulbs, you should be ok there. If there is too much resistance on that side, the bulbs should be blinking like crazy.
25 Aug 2021 15:16The horn may have rusted internally.
25 Aug 2021 16:10
Horns are funny in that a little tweaking of the adjustment screw can make them go from dead to full scream. For sanity's sake you might want to jump wires from the battery to the horn to see if it still works.
The following user(s) said Thank You: DOHC, Skidmark
