650 Mod's 78 Fighter Build
- Drooz
Re: Re:650 Mod's 78 Fighter Build
03 Mar 2015 18:21
    Man, I think I like that.
      '77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
    The following user(s) said Thank You: 650mod
- 650mod
       Topic Author Topic Author
03 Mar 2015 18:32
    Thanks, Drooz! I can finally see some light at the end of the tunnel!
      78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
Re: 650 Mod's 78 Fighter Build
04 Mar 2015 06:04
    looks good sir. :evil:
- 650mod
04 Mar 2015 16:43
    Thanks, Leon!
      78 kz 650 custom
- Arnold
07 Mar 2015 12:12
    Looks good !
Just make sure you can grab the nut for the swing axel,,, :whistle:
      Check out my project at:
kzrider.com/forum/11-projects/550823-ret...100-82-goes-z1-clone
- 650mod
07 Mar 2015 20:20
    We'll machine some of the inner round stock down so it opens that area up a little more for a socket  All in the head scratching, one step at a time
      78 kz 650 custom
- 650mod
17 Apr 2015 16:15
    Alright, so some progress was made today. I swung by the shop and took measures into my own hands- my welder is busy working on a guitar right now so he has limited play time.
I started off by clamping the mounts down to the frame to see if I would have to mill any material off the mounts to fit the socket in. Luckily enough, we're good to go.
After lining things up and making sure I felt like this would be a good foot placement, I had the pegs tacked into place to do a dry run for the foot positioning. It actually feels really good where they're at.
I also got some work done on my passenger rest mounts, those should be on by early next week. I'll have pictures up with the work that gets done. I took 3/8ths plate steel and cut it down to a rough size, Clamped the mount in place, spun it until I had the right angle to rest the foot on, then traced the mount into the steel. The next step will be to cut the mount down and tack it in to the frame and see how things feel with a passenger on.
By the end of next week, I'm hoping to have my gauge mount on, the passenger pegs on, and the steering stops done.
Attachment 20150417_114017450x800.jpg not found
Attachment 20150417_114043450x800.jpg not found
Attachment 20150417_165437800x450.jpg not found
Attachment 20150417_165447800x450.jpg not found
      78 kz 650 custom
20 Apr 2015 06:38
- 650mod
20 Apr 2015 16:34
    She's getting there! I have a break tomorrow during the day that I'm hoping to get the passenger peg mount design fully finished on and maybe cut one/drill and tap it. After that, it's steering stops, a gauge mount, and a few small welds on the frame to finish stuff up. Then off to powder coating
      78 kz 650 custom
- 650mod
01 May 2015 15:47
    over the last little bit I managed to get a passenger peg mount design thought up, checked angles of the mounts, and fabbed/had them tacked in place. Here's what has happened in this department.
I got a feel for where and what angle I wanted the passenger pegs mounted. I then took my 3/8ths plate steel and made a rough model of what I wanted to do. Cut it down, sanded the edges, and tapped the holes.
Checked to make sure my design was going to line up to the holes and look ok.
Did a quick frame mount check to see how the angle of the mount would look and feel for the passenger. Had the height and angle verified by a "passenger". Everything was ok.
So we tacked the mounts in place, and did a double check for the angle of the pegs when they were on. Everything looks level and at the right height
Nice and square to the frame and level to the ground. Another thing to check off on the to do list.
Devin
Attachment 20150422_131514450x800.jpg not found
Attachment 20150422_131622450x800.jpg not found
Attachment 20150422_132028450x800.jpg not found
Attachment 20150501_165355450x800.jpg not found
Attachment 20150501_165402450x800.jpg not found
Devin
      78 kz 650 custom
04 May 2015 06:46
    the ol' punch list is getting shorter!!! :lol:
- 650mod
04 May 2015 13:53
    She sure is! I got headlight pot mounts made yesterday too, I just have to get those welded up. Then steering stops, a reservoir mount, and it's off for powder coating!
Devin
      Devin
      78 kz 650 custom
