76 KZ900 LTD Streetfighter build
- Haybus
- Big Al
Re: 76 KZ900 LTD Streetfighter build
11 Aug 2013 02:08
My dash arrived. So excited to bolt it up, but of course like everything else, the standard bracket doesn't work. Mostly because I made my own upper triple clamp and guessed where the bar clamps should be. But I don't think I would have used it anyways because it would have put the gauge way up above the bars.
So a little head scratching and mill work later and I'm liking where it sits. It's tucked in about flush with the top of the bar clamps. The supplied bracket for mounting the speed sensor doesn't seem to work with USD forks. Probably need to make my own bracket.
Alan
Attachment DSCF2098.JPG not found
Attachment DSCF2101.JPG not found
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- 650mod
11 Aug 2013 21:30
Looks really clean, Al! Did you buy the unit new? I was bidding on a unit like this on ebay, lost the bid
I love how it looks though, definitely fits her well
Devin
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- Haybus
- Big Al
11 Aug 2013 23:14
Devin, I bought it new. $270 from Amazon was the cheapest I could find. Makes it the most expensive part on the bike now.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
12 Aug 2013 10:45
looks perfect sitting there!
:evil:
:evil:
- 650mod
12 Aug 2013 22:20
They're expensive, but nice, units. I might just have to dish out for one...
78 kz 650 custom
- Haybus
- Big Al
19 Aug 2013 01:45
Got a few of the last bits tidied up this weekend. Wired up the gage, yea
Machined a bracket to clamp the supplied bracket for the speedo hall effect sensor to the fender mount and tuck it up nicely behind the fender.
Machined some adapters to mount the blinkers.
On my 3rd set of mirrors I hate and can't see out of. Might try mounting the Emgo bar end mirrors again and run them under the bars. They're not great either because they're not convex.
Did some riding and the bog is only at 4000-4500 rpm, and/or 1/2 throttle. Raised the needles 1 clip position. Seems worse, a lot of hesitation now where before it was just a flat spot. I can power through it with a twist of the wrist. Lower the needles 1 position from where they were now? Could the flat spot have been from a rich condition with the needles?
Alan
Attachment DSCF2107.JPG not found
Attachment DSCF2108.JPG not found
Attachment DSCF2109.JPG not found
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- DesertKZ
19 Aug 2013 14:42
Man I hate you... that gauge is so cool.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- Haybus
- Big Al
22 Aug 2013 03:00
Crap, I think my stator is dead or dying. Low voltage, around 20VAC, on one leg to the other two. Can't get any resistance on that leg so I'm surprised it even doles out any volts. Need to do some more checking before I call it dead, but I'm pretty sure. Might as well upgrade to the reg/rec combo while I'm at it. Only just get into the 13VDC range on the battery now at 5000rpm. No sense in doing any more carb tuning until this is straightened out.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
23 Aug 2013 10:25
:pinch:
- Beaner242
23 Aug 2013 10:50
great bike. love it.
1982 KZ1000K LTD Chopper
- Haybus
- Big Al
26 Aug 2013 00:19
Whoohoo, just saved my stator!! Had a broken wire. Now she's charging, AND took care of my tuning issues. She runs like a champ now, except at 0-1/8 throttle. I'm at 1/2 turn out on the air screws and she's almost good. I've read as little as 1/4 turn is all the 29's need. Seems a little flat just idling in 1st gear up to 2000 rpm. After that she takes off like a beast. At around 4000 rpm and up that Russ Collins pipe sounds like a trumpet. So cool.
Still have to sort out the mirrors. Need a new right rearset so I can actually use the rear brake, if ever. Either need a new tank strap or make a better method to hold the tank down. It slides back a little and rattles like crazy. And lastly, make new side cover badges that say BA1000
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- bluezbike
26 Aug 2013 00:55
Nice save on the stator...everything is looking really awesome Alan
79 KZ 1000 LTD
