76 KZ900 LTD Streetfighter build
- Haybus
- Big Al
Re: 76 KZ900 LTD Streetfighter build
25 Jun 2013 01:45
Devin, they should be the same diameter, within 0.25mm or less. You could sleeve the bracket without affecting anything. Or try to find a bracket that matches your swingarm and fits the shaft, but it may not exist.
Alan
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- 650mod
25 Jun 2013 10:43
Al,
I ran part #'s and dialed everything in with my digital caliper- turns out the guy I bought the rear brake assembly from had it labeled as a 96-98 model year system, so I bought it. Turns out the rear axle diameter was the same on the 96-97 model year (25mm), then downsized to a 20mm for 98-99 (that's what I have). The calipers are interchangeable, and removable from the mounts, so I ordered in the proper mount (which should solve all my issues). It was just a pain that we lost 2 hours of build time trying to figure it all out...
Devin
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
- Haybus
- Big Al
30 Jun 2013 22:43
Been kind of a slacker lately. Got my shift linkage figured out. Need to add some locking nuts, but I'm waiting for the real chain to show up next week. Then maybe a short ride to whet my whistle before getting into the paint
Alan
Attachment DSCF2077.JPG not found
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- bluezbike
01 Jul 2013 02:04
That looks pretty sweet Alan...I really like the gear change set-up
79 KZ 1000 LTD
The following user(s) said Thank You: Haybus
- Haybus
- Big Al
01 Jul 2013 02:32
Thanks, I'm pretty happy with how it turned out. Need to cut off the heim joint bolts sticking out, or maybe stainless acorn nuts? Also need to make a stop for the kick stand as it interferes with the linkage at full retract. Either bond on a shim inside the clevis or make a clamp on stop attached to the frame. Next up is the tail light bracket.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
02 Jul 2013 11:32
looks real nice al good job.
- Haybus
- Big Al
07 Jul 2013 00:56
Made a tail light bracket. I know, I copied Testarossa's idea. But if it looks good on another bike, I'm gonna use it.
Started sanding down everything to prep for painting. Tank and side panels, no problem. Tail had some chips that started flaking when I tried to feather them out. Many hours later the whole tail is peeled using a utility knife and occaisonally a heat gun.
Got the chain on too. Don't like the thin bushing on the shifter so I need to fix that up. Besides paint, Feels like I'm working on a short list to completion. But lots of busy little bits to button up.
Alan
Attachment DSCF2079.JPG not found
Attachment DSCF2081.JPG not found
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- 650mod
07 Jul 2013 07:14
Almost there! What's that tail light off of? Looks sexy!
Devin
Devin
78 kz 650 custom
- Haybus
- Big Al
07 Jul 2013 11:48
I believe it's 03-05 R6. eBay $10. It's nice and bright.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- DesertKZ
08 Jul 2013 11:07
Looks awesome. How close is that plate to the tire? Only reason I ask is I'm running an LED tail light and never would have though in a million years it'd contact my tire, until I ran 2-up and hit some pretty good bumps. :ohmy:
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- Haybus
- Big Al
08 Jul 2013 12:36
It's about 5" to the tire. I deleted all the 2up stuff. I don't like the plate location but I don't have any other good options. I may crease the plate a little so it doesn't look so straight up and dicular.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- DesertKZ
08 Jul 2013 13:05
Looks great. I'm so jealous of your rear set-up, I want to head that way but I ride a shaftie and the thought of all that work gives me a migraine... haha
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
