- Thank you received: 42
76 KZ900 LTD Streetfighter build
- Haybus
- Big Al
Attachment DSCF1951.JPG not found
Is the kick starter just blocked off or was it deleted from the factory? I was thinking maybe the LTD's didn't come with one but I've seen loads of LTD pictures with kick starters. Just curious.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
- Haybus
- Big Al
Attachment DSCF1948.JPG not found
Frame is broken as you can see in the picture. So first will be a complete tear down with frame gussets. I like the flame paint job. Very subtle, they only show up on a bright day. Just looks burgandy in the garage. Unfortunately the guy I got it from let the master cylinder leak on the right side of the tank, otherwise I might keep the pain like it is, rock chips and all.
2005 FJR
2009 Hayabusa
- wireman
- Thank you received: 299
Youll have to measure the width of the pivot tube on the zx arm compared to the stock one
- wireman
Is there a steering head lock on the steering head where the vin number is located?
If theres a lock by the vin number Im gonna guess 79-80 1000 ltd,If its built into lower triple tree Im gonna guess 77-78 ltd frame.
Whats vin number on frame?
- trianglelaguna
- Thank you received: 236
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Haybus
- Big Al
Are the carb's not stock? Bike runs great if you hold the left most plug wire back a bit so the spark has to jump. Otherwise it drops a cylinder or two intermitently. Figure it will need a bit of electronic updating.
2005 FJR
2009 Hayabusa
- Thank you received: 2098
Per Zedder:Haybus wrote: Z1F-090121, same as on the title. Sticker says date of manufacture is 1975, title shows 1976. There's no lock that I can see. Was it a separate lock or multi-position key? The key only has on and off.
Year & Model '76 KZ900-A4
Frame No. Range Japan MFR Z1F-085701 - 117060
USA MFR Z1F-500001 - 510340
Engine No. Range Z1E086001 - 138846
1976 KZ900 standard model had a drum rear brake.
Haybus wrote: New to the forum, but not to riding. Ride year round, exept the few days it snows.
Looking to turn my 1976 KZ900 LTD into a street fighter. Frame is broken on the left side right above the exhaust so it will be a complete tear down.
Attachment DSCF1947.JPG not found
Rear fender looks like 1976 KZ900 LTD.
Front fender is 1977 or later KZ1000LTD.
Fork lowers don't appear to be 1976 KZ900LTD.
Points cover isn't from 1976 KZ900, and is from a later model.
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- Haybus
- Big Al
2005 FJR
2009 Hayabusa
