76 KZ900 LTD Streetfighter build
  • wireman
  • wireman's Avatar
Re: 76 KZ900 LTD Streetfighter build
23 Nov 2012 23:55 - 23 Nov 2012 23:56
#559815
Attachment popcorn_2012-11-23.gif not found
B)
Last edit: 23 Nov 2012 23:56 by wireman.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
24 Nov 2012 01:03
#559825
cool the zx6 is a nice one.
you plannin to use dual shocks?
  • Haybus
  • Haybus's Avatar Topic Author
  • Big Al
24 Nov 2012 03:23
#559835
Yeah, I like the look of duals. Maybe some ZRX shocks. My friend has a ZRX and I've always thought it was good looking.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • 531blackbanshee
  • Vendor
24 Nov 2012 15:23
#559874
did you see the zx swingarm i did for revboyz where i modded the caliper bracket and welded the shock brackets on?
kzrider.com/forum/5-chassis/509475-zx6r-...rm?limit=20&start=40
he bought his shock brackets from somewhere online and got a pretty good deal.
  • Haybus
  • Big Al
24 Nov 2012 17:20
#559880
Yes I did Leon. That looks good. Lots of good fabrication ideas on here. I'll either go that route, make a new caliper bracket on the mill or rotate the caliper to the bottom and make a stay arm. Just have to see what look I like. Should get the swingarm next week, then I'll start mocking things up.
Alan
2005 FJR
2009 Hayabusa
  • 531blackbanshee
  • Vendor
24 Nov 2012 22:35
#559914
with the caliper on the bottom it puts the bleeder on the bottom.
and,the caliper mounting bolts end up behind the caliper.so that a brake stay arm would have to wrap around the caliper.
  • Haybus
  • Big Al
25 Nov 2012 02:03
#559948
Yep, I can see that now Leon. Thanks.
2005 FJR
2009 Hayabusa
  • Haybus
  • Big Al
30 Nov 2012 03:17
#560595
Yea, parts arrived tonight. Thought I would throw it all together for a quick photo op. Looks like the swing arm will fit the frame nicely, and more importantly it's plenty wide for that wheel. Thanks for the tip Leon.
Attachment DSCF1973.JPG not found
Keep the seat for a muscle cruiser look?
2005 FJR
2009 Hayabusa
  • 531blackbanshee
  • Vendor
30 Nov 2012 10:56
#560624
looks good :evil: !
keep us posted on the progress.
  • Haybus
  • Big Al
01 Dec 2012 02:43
#560756
Got my stems pressed out and ready to bore out the ZX stem to be the sleeve for the KZ stem. Measured up what I need for spacers on the swingarm. Fire up the lathe and it's making a stange scrubbing sound. Wham, break the variable drive belt. So much for my Saturday plans.
Alan
2005 FJR
2009 Hayabusa
  • Haybus
  • Big Al
02 Dec 2012 00:28
#560889
Got some lathe work done in spite of mine being down until the new belt arrives. Bushed up the KZ stem and pressed it back into the ZX triple, so it's not just propped up in the picture. Made spacers for the swingarm. Can't believe how loose everything is by design on the KZ and ZX. swingarms 0.010" clearance on shafts and bearings? That's crazy, so I tightened everything up. That ZX6 bearing set up is wierd.
Attachment DSCF1974.JPG not found
Attachment DSCF1977.JPG not found
Suggestions for removing the drive sprocket when you can't step on the rear brake? Something I can hold on the dyno or clutch side? Otherwise I'll make a tool that slips over the sprocket so I can hold it.
2005 FJR
2009 Hayabusa
  • trianglelaguna
  • trianglelaguna's Avatar
02 Dec 2012 00:36
#560890
put it in gear...put a big ass breaker bar on the nut heavy end upstroke and give it a tap on the end with a mallet , whap...it will come right loose
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
