76 KZ900 LTD Streetfighter build
- Haybus
- Big Al
Re: 76 KZ900 LTD Streetfighter build
21 May 2013 11:05
The installation is easy. The static timing is easy, but a bit akward. The timing is based on full advance so you have to hold the magnetic rotor full advanced while rotating the crank and watching for the test light or needle movement on a volt meter. Do that a couple times to make sure it's right, then move to the other 2 cylinders. I hadn't started her in 2 weeks and she fired up immediately. I didn't check, but I'm guessing I got the fat blue spark Patton is so fond of.
Alan
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
- 650mod
21 May 2013 12:22
Awesome. Sounds like it should be a fairly quick swap over. Thanks, Alan!
Devin
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
21 May 2013 13:22 - 21 May 2013 23:57
On models with adjustable timing, am thinking that any ignition may be statically timed based on advance marks with the advancer weight arms held open.
Such method avoids any vagaries in advancer function between closed and open (resulting from such things as missing rubber pads on the weight arms).
Another option for static timing the Dyna-S is using the standard method of aligning the F mark with the case mark, which then relies on the advancer to properly perform the function it was designed to perform by advancing to the correct running position when the weight arms become spread wide open.
With Dyna-S or other ignition, it's a good idea to follow up static timing (engine off) with dynamic timing (engine running) by viewing alignment of the advancer marks with the case mark under a timing light.
If desired, further minor fine tuning adjustments may be made by slight movement of each Dyna-S pick-up coil to separately perfect 1/4 and 2/3 timing. Am thinking this feature might be more useful when installing Dyna-S in models produced without owner-adjustable ignition timing.
Attachment not found
Last edit: 21 May 2013 23:57 by Patton.
- kzz1king
21 May 2013 21:30
I am unsure if this is the proper way but when I time mine I just install a plug in the lead and slowly turn/adjust until it sparks at the proper time. I also fine tune the other pick up the same way.
Wayne
Wayne
Home built KZ1000 turbo setup
- Haybus
- Big Al
13 Jun 2013 21:11
Still working on it, just not much worth showing. Got the front brakes installed and made a splitter. Built a battery box, sorry no close up pic. Rear rim back from being straightened, polished, painted and tire mounted. Next up buy a chain, make a shift linkage, mount the lights and paint.
Alan
Attachment DSCF2076.JPG not found
Attachment DSCF2074.JPG not found
Attachment DSCF2075.JPG not found
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- bluezbike
14 Jun 2013 02:29
That looks really good man, stance is fine!!!You going to run without a front mudguard?
79 KZ 1000 LTD
- Haybus
- Big Al
14 Jun 2013 02:40
I have a zx10 fender, just not sure I like it. I may paint it and see if it grows on me.
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
14 Jun 2013 09:47
very nice. :ohmy:
love it :evil: !
whats the paint going to be like?
love it :evil: !
- Haybus
- Big Al
14 Jun 2013 11:14
Tank and tail will be red with the white stripes and flat black between them. Side panels will probably be solid red. Front fender will be red down the middle and flat black down the fork leg protectors (if I use that fender).
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
14 Jun 2013 11:47
sounds cool man :evil: .
can't wait to see it.
i was just wondering on the way in to work this morning where you had been lately .
then i log in and you have posted :lol: .
The following user(s) said Thank You: Haybus
- Haybus
- Big Al
14 Jun 2013 13:50
Always here, just find there's a lot less bike time available now the weather is nicer. My daughter graduates high school tomorrow and next weekend is my annual beer drinking, dirt bike riding, pellet gun shooting mans weekend competition. I have a championship to protect so I can't miss it. Will need to get more creative at finding time to finish this up.
Alan
Alan
2005 FJR
2009 Hayabusa
2005 FJR
2009 Hayabusa
- CruisingRam
14 Jun 2013 16:41
Great job!
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
