76 KZ900 LTD Streetfighter build
  • kaw corral
  • kaw corral's Avatar
  • Banned
  • Lets build one!
Re: 76 KZ900 LTD Streetfighter build
29 Apr 2013 22:23
#584762
do what u will but with a frame like that clearly shows that bike went down hard one time.Care to trade them carbs for a good frame and a set of correct carbs for that motor.?
74 Z1 900
75 Z1 900
2 - 76 KZ 900
76 KZ LTD 900
77 KZ 1000
77 KZ custom 1075
78 LTD 1000
80 LTD 1000
2000 KZ Police 1015J
83 HD FLH 1340
79 FXE SG custom 1200
78 FXE SG custom 93""
  • Haybus
  • Haybus's Avatar Topic Author
  • Big Al
29 Apr 2013 23:37
#584800
Yeah, clearly from pictures you can see the frame is bent. :S if you could point to where, I'll start generous applications with a sledge hammer. The smooth bores are awesome and aren't going anywhere but on my bike.
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
30 Apr 2013 10:31
#584899
kaw corral wrote: do what u will but with a frame like that clearly shows that bike went down hard one time.Care to trade them carbs for a good frame and a set of correct carbs for that motor.?
The following user(s) said Thank You: Haybus
  • 650mod
  • 650mod's Avatar
30 Apr 2013 14:55
#584940
All I can say here is, what a sexy beast... I can only hope mine comes out as clean and fresh looking as your build. Again, very nice work! Looking forward to the end product!
Devin
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • Haybus
  • Big Al
01 May 2013 00:04
#585039
Thanks for the nice comments everyone. I'm really enjoying working on it. I too am looking forward to the end product.
2005 FJR
2009 Hayabusa
  • Haybus
  • Big Al
18 May 2013 21:21
#588104
Not a lot of progress lately. Weekends have been maintenance on cars and my daily driver motorcycles.
Polished and painted the front rim. First time I've polished a wheel. Not my favorite task, but the result is worth it. Went to mount the calipers and apparently I repurposed the bolts for the foot peg mounts. 10mm fine is a bit harder to find in stainless.
Attachment DSCF2072.JPG not found
2005 FJR
2009 Hayabusa
  • 650mod
  • 650mod's Avatar
18 May 2013 22:48
#588118
Wow, that really dresses the rim up... :)
78 kz 650 custom
  • 531blackbanshee
  • Vendor
20 May 2013 12:42
#588336
really nice job sir :evil: !
  • Ederer
  • Ederer's Avatar
20 May 2013 12:59 - 20 May 2013 14:04
#588339
Looking good!
I ended up buying from ARP for my caliper bolts. They had some stainless bolts with nice heads that were perfect for not as much $ as you might expect coming from ARP.
edit, this is what I used. Might be slightly different for your forks but perhaps a good starting point if you are looking around.
Bolts, Hex Head, Stainless 300, Polished, 10mm x 1.25 RH Thread, 70mm UHL, Set of 5 part number 763-1009
Last edit: 20 May 2013 14:04 by Ederer.
  • Haybus
  • Big Al
20 May 2013 20:36
#588419
I was going put the stock caliper bolts in and get new SHCS bolts for the foot pegs. 10mm-1.25 x 45mm, doesn't seem like I'm asking for a lot, but damned if I can find them in stainless. I can find regular hex or flange head bolts, but not socket head. Too bad they're not Freedom threads.
Alan
2005 FJR
2009 Hayabusa
  • Haybus
  • Big Al
21 May 2013 01:04
#588464
I've read about the Dyna electronic ignition firing the coil(s) when you turn on the ignition. Still didn't prepare me for the pow when I got it all wired up tonight. Thought I blew something. :ohmy: Excellent throttle response, idles like never before. Can't wait to ride her, but need to be patient. So many little things to do still.
Attachment DSCF2073.JPG not found
2005 FJR
2009 Hayabusa
  • 650mod
  • 650mod's Avatar
21 May 2013 08:30
#588482
Sounds like it did the classic "clean the cylinders out when the key is turned" :P
I just picked up a Dyna for my 650, along with new Dyna spark leads. Overall, how tricky was it to get everything hooked up, and to get the timing set right?
Devin
78 kz 650 custom
