'76 KZ900 (ZRX1200R) Build
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: '76 KZ900 (ZRX1200R) Build
07 Aug 2012 07:22
#541155
or u could mount it on top of the tree's like the modern bikes do.
thats what i did.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
  • NakedFun's Avatar Topic Author
07 Aug 2012 09:28
#541168
Mark,
I looked at that this morning but will have to give it more thought! Didn't have coffee yet....
Greg,
Yes, I still have them but didn't know you would be interested in cut off frame components! If you want them, I'll send them your way. I think I still can find your addy.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Aug 2012 22:39 - 07 Aug 2012 22:41
#541291
Lots of ways to do it. this was my way. seem to work well.
Attachment kzsteeringdamper0141.jpg not found
i got the idea from my track bike.
Attachment kzsteeringdamper0041.jpg not found
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 07 Aug 2012 22:41 by mark1122.
  • NakedFun
08 Aug 2012 00:21
#541310
Mark,
I really like your track bike components. I like the idea, but I think if it and my oil cooler play nicely together, they both go behind the lower triple and mount off the frame neck.
Cory
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
08 Aug 2012 10:15
#541347
NakedFun wrote: Mark,
Cory
cant go wrong there. it should look great. B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
08 Aug 2012 11:11
#541355
Getting anxious not really able to get anywhere on the bike so far, waiting on parts. Some showed up though. My new Tokico 4 pots that I am trying on my ZRX showed up, which means the 6 pot ZRX ones are moving to the KZ. I ended up selling both pair of calipers this week for bike funding since I didn't need them. Running EBC HH pads on all my bikes now. Should be trailering the bike this weekend to the shop and beginning the welding and cutting I need to do over this weekend and the next. Should be lots of pics for that. Hopefully my offset sprocket will be here this week so I can check frame clearance. Dreaming up gauge mounting and damper mounting. My 43mm damper fork clamp showed up, so playing with that... Still I dislike low project momentum.....
Cory
1976 Kawasaki KZ900
  • NakedFun
08 Aug 2012 22:25
#541472
OK, so lookey what showed up.....the other non-offset is for my ZRX.
5/8" offset
So swapped it in, and without milling the rear hub, the chain just touches the angled up tube, barely.... Probable need to take about 3/16" off the hub.
Here is a pic of the stock headlight in place, mocking up for gauges, steering damp, etc....
Here are my 4 pot Tokicos that will be going on my ZRX, but thought I would hang them somewhere....
Here is the aftermarket header I am trying to salvage as you can see it has hit a few things...but I want to keep it working as I have a killer idea for a custom exhaust.....
Will report more from this weekend....
Cory
1976 Kawasaki KZ900
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
09 Aug 2012 17:19
#541585
just curious, how much $ does PBI charge for the kz 5/8" sprockets ??
that pipe may be too far gone, but u could try this. plug the ends, inflate the inside of the pipe to 10 or 15 psi, then heat the dent with a torch. apparently the dents can be popped out this way ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • NakedFun
09 Aug 2012 17:55
#541591
Oh, I can fix the header. Localized heat and a variety of chrome steel ball bearings that are rammed through the inside of the pipe a step at a time. I still need to pick up my finishing ball that is 1.375". Works pretty well.
The KZ sprockets are $40.00 USD. Very high quality. Have them in 1/4, 3/8, and 5/8" offsets.
Cory
1976 Kawasaki KZ900
  • NakedFun
09 Aug 2012 23:39
#541653
So, I spent some time on the mill today....Mark & Co convinced me to move the shocks forward and lean them.
So here are the finished goods, but they need to be welded in this weekend.
Nice tight fit to the tube radius, should weld nicely.
Cory
1976 Kawasaki KZ900
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
10 Aug 2012 13:42
#541756
ahh,sweet! :)
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
10 Aug 2012 17:52
#541795
thats a Very good price on the sprockets.
just wondering if the spool from a zrx will fit on the end of that shock mount? i always thought they would make a good slider in an crash ? did u say that u have a zrx?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
