THIS TIME ITS A DRAGBIKE
  • racer54
  • racer54's Avatar
Re: THIS TIME ITS A DRAGBIKE
19 Apr 2012 22:54 - 19 Apr 2012 22:55
#516783
Cashio Cycles
8391 HWY 23
Belle Chasse, LA 70037
Contact Paul
504-393-2260 office
504 458 5237 cell
pcashio@cox.net
Last edit: 19 Apr 2012 22:55 by racer54.
  • z1kzonly
  • z1kzonly's Avatar
20 Apr 2012 02:10
#516813
Search "Jack" from Ontario Canada. His blue Mark II 1500cc dragbike. He took off the stator and rotor.
Built a starter with some high amp batteries. His dragbike is a starter button bike.
And very nice also.
  • z1kzonly
  • z1kzonly's Avatar
20 Apr 2012 02:23
#516814
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Apr 2012 12:43 - 20 Apr 2012 16:26
#516890
Your bike is looking great. B)
i use a Honda starter for my kz1200 but it is only 10.5:1.
the H starters turn over faster than the kz's.
i forgot to check back on your post, u asked about the basket springs.
they are there to take the shock out when u launch. without them the crank and trany would be connected solid, so they compress to lessen any damage to the power train. it is common for them to get week, and brake. i found a broken 1 in my pan. APE has a replacement CLUTCH HUB REBUILD KIT, (spring package) $95.
kzzone.com/clutches.html
I changed mine out . its not dif but u may need a press. u drill out the old rivets , take it apart, and then smooth the inner spring pockets with a dremel. the springs can chew the mating plate surface up. then u press the new rivets in and weld them.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 20 Apr 2012 16:26 by mark1122.
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
20 Apr 2012 15:51
#516929
This thing is looking good! I'm a dragbike person and I'm liking this. Can't wait to see the finished rocket!
Les
  • JEFFG1
  • JEFFG1's Avatar Topic Author
20 Apr 2012 21:41
#516987
THANKS GUY ALOT OF GOOD INFO I WILL LOOK INTO THE STARTER THING THIS WEEK END SURE WOULD BE NICE,MARK I DID CHECK THAT BASKET AFTER YOU SAID THAT AND 2 SPRINGS WERE LOSE SO I AM GOING TO USE ANOTHER ONE THAT I HAD THAT IS GOOD AND TIGHT.I HAVE HAD MY BUTT ON THE ORANGE ONE THE LAST FEW DAYS LOOKS LIKE WERE GOING TO GET ABOUT 5 DAYS OF COLD WEATHER HERE SO I MITE GET ALITTLE MORE DONE ON THIS ONE. GOT TO GET PAINT ON THE MOTOR ,MAKES ALOT OF SENCE 2 DAYS WORTH OF WORK GETTING THE PAINT OFF JUST TO PAINT MORE ON :dry: THEN I CAN BUILD THE SHORT BLOCK ANYWAY
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
  • Kawboy74
  • Kawboy74's Avatar
20 Apr 2012 23:15
#517008
Hey Marty I just left a post in the fallen riders category, we lost Jack this week guys! Great guy with a lot of drag bike talent and know how! Big loss due to the famous c word.
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • JEFFG1
24 Apr 2012 20:52
#517871
i did some checkin on the starter thing then i checked on the budget thing its not there so that isnt happening this year.stopped up to a buddy of mine and he brought out a extended kiker shaft that sticks out far enough that when you kick it you dont hit the pipe so am going that route.i will still use the outboard starter to. i have been doing some research on the 2 tracks that i will be running at and they dont have a box class unless your in a pro class (iam not) so my question is how do people bypass the box.they unplug them and take them off.now i dont know shit from cupcakes when it comes to this but there is alot of wireing on this thing has anyone ever done this i know this is a shot in the dark but i figure most of them are wired about the same i still want everthing to work. any help would be great if not well iam not sure what to do. i dont know anyone around me that has this stuff.
Attachment DRAGBIKE225.jpg not found
Attachment DRAGBIKE224.jpg not found
  • JEFFG1
25 Apr 2012 20:29
#518063
got paint on the motor moving rite along
Attachment DRAGBIKE229.jpg not found
Attachment DRAGBIKE231.jpg not found
Attachment DRAGBIKE230.jpg not found
  • racer54
  • racer54's Avatar
25 Apr 2012 20:47
#518068
Turned out great...what paint did you use?
  • JEFFG1
25 Apr 2012 20:58
#518071
racer54 wrote: Turned out great...what paint did you use?
used a ppg etch primer and 2 coats of vht gloss black did the same on my orange bike and it still shines holds up great
  • ramtough_63
  • ramtough_63's Avatar
25 Apr 2012 21:06
#518077
sweeeeet!!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
