KZ1000 Police conversion to cafe custom
- Cuff
Re: KZ1000 Police conversion to cafe custom
05 Dec 2012 14:34
As a rule you shouldn't run a front tire on the rear unless your talking about a very light and underpowered bike.
I'm running these with decent results but in hind sight I would like to go a little bigger and run the 130/80 TL or the 4.10 TT. The 120/80 just looks too small. www.motorcycle-superstore.com/11/53/802/...Sport-Rear-Tire.aspx
I did have these before but they wore out real quick being a lighter tire that should not have been on the bike in the first place. (HF308 on the page)
www.bigtoppowersports.com/eshopprod_cat_...ERSAL_REAR_TIRES.htm
My next set will be these.
www.bigtoppowersports.com/eshopprod_cat_...K70__K81_VINTAGE.htm
- sweetbro
05 Dec 2012 15:05
Holy GEEZZUUSSSSS! That Dunlop costs as much as my race tires on my R1?!?!?!?! Thats insane. At least you can get the bigger 4.25. I'll see what happens with the 2 fronts.
- Cuff
05 Dec 2012 15:53
That's because it's a canadian site. Should be cheaper down there. I'll more than likely pick them up down south and have them shipped to my secret bunker just over the border.
The following user(s) said Thank You: sweetbro
- sweetbro
05 Dec 2012 15:55
Ha, ok. I about had a heart attack, geez.
Good looking tire tho
- sweetbro
11 Jun 2013 12:42
So I have not been on here in months and months, but I fixed an issue that I was having. If you look back in this post, I had an issue with the shift rod moving laterally. So I found a bearing that has the same ID as the OD of the shift rod, I then had my friend with CNC mill open up the case so I could set the bearing into it. It came out really nice and works perfect. The shifting is super smooth and tight.
The following user(s) said Thank You: Ed_in_Miami
- Jimbo302
01 Dec 2018 02:21 - 01 Dec 2018 02:21
I know its old, but Thanks for the detailed posts, great read and nice bike.
Last edit: 01 Dec 2018 02:21 by Jimbo302.
