KZ1000 Police conversion to cafe custom
- sweetbro
Re: KZ1000 Police conversion to cafe custom
07 Aug 2012 13:51
I clicked a few more pics! I also removed the rear fender and put in a plate that completely covers the underside of the seat.
- sweetbro
07 Aug 2012 14:39
Carb question real quick, my carbs had 127.5 main jets in them and I replaced them with 132.5 after I did the pipe/cone filters. I did not replace the pilot jets. Stock is claimed as 38. Should I do 40s or 42s? What would you guys say? I live at sea level. It runs pretty good, but has a LOT of popping on decel and if I am just cruising at like, 30mph.
07 Aug 2012 18:12 - 07 Aug 2012 18:13sweetbro wrote: Carb question real quick, my carbs had 127.5 main jets in them and I replaced them with 132.5 after I did the pipe/cone filters. I did not replace the pilot jets. Stock is claimed as 38. Should I do 40s or 42s? What would you guys say? I live at sea level. It runs pretty good, but has a LOT of popping on decel and if I am just cruising at like, 30mph.
If not already done, would first try enrichening the pilot circuits by turning all pilot mixture screws out counter-clockwise by 1/2 turn, and by 1 full turn or more if popping persists.
Another consideration is that the pilot circuits may be obstructed.
Or running lean due to missing parts such as plugs or o'rings at base of pilot jets.
Or too low fuel level in float bowls (as determined via clear-tube test).
Last edit: 07 Aug 2012 18:13 by Patton.
- sweetbro
07 Aug 2012 19:05
Ok, cool, thanks. I am gonna try that right now.
- Cuff
07 Aug 2012 21:27
Looking good keep going. I made a similar box for the under seat wiring as well. Cleans everything up and easy to work on. One question about the battery mount though. Although it's really cool looking, will the movement of the swing arm affect the battery in a negative way, i.e. shock?
- sweetbro
07 Aug 2012 21:35
Yea, I thought about that, but there are plenty of dudes that ride around on rigid frames. I dont really see a difference. And hey, if my battery fails I can move it back. I really dont think that it will have any problems.
- kzz1king
08 Aug 2012 11:41
The swingarm is still active. The battery is not mounted rigid so should be easier on it than a hardtail.
Wayne
Wayne
sweetbro wrote: Yea, I thought about that, but there are plenty of dudes that ride around on rigid frames. I dont really see a difference. And hey, if my battery fails I can move it back. I really dont think that it will have any problems.
Home built KZ1000 turbo setup
- 2ndgenKZ
- 750 LTD
11 Aug 2012 18:56 - 12 Aug 2012 17:16
badass build.
you've given me some idea's for my KZ750 ltd (that pic of that xs with dualsports on a few pages back sealed the deal). Any chance your freind could make another seat pan?? local guys are pulling the fillings out of peoples teeth here in atlanta.
may ask him to fab up rear brake caliper tabs. using alot of gas when you have to down shift all the time
bad ass build though, feelin it.
1983 Kawasaki KZ750 LTD MAC
1983 Kawasaki KZ750 LTD BONES
1981 KZ750E KERKER
1985 Dodge Conquest FLATTY
1995 Jeep Cherokee RUSTY
1981 KZ750E KERKER
Last edit: 12 Aug 2012 17:16 by 2ndgenKZ.
- sweetbro
13 Aug 2012 01:53
Ha, He is the one that made me the spacer that replaced my caliper mount. I rarely run rear brakes on any bike, and the master was seized on this bike, so even more reason.
As for the seat pan, he might be up for it. I will get back to you about that. What do you think a reasonable price would be for a basic seat pan like mine?
- 2ndgenKZ
- 750 LTD
13 Aug 2012 02:31 - 13 Aug 2012 02:42
Id say $60-80 bucks (if it took him an hour), plus I gotta pay shipping so hopefully not too bad
had to come back and edit this... may have to bite the bullet and get it done around these parts or do it myself. CNC just makes it look soooo much better.
I have a 750 LTD frame, little different I believe from yours (definitly gonna chop some off, but still).
thanks for asking though, still curious
1981 KZ750E KERKER
1981 KZ750E KERKER
Last edit: 13 Aug 2012 02:42 by 2ndgenKZ.
- sweetbro
14 Aug 2012 14:36
Quick teaser, I got this quick cell phone photo of my seat. Not the best picture, but I will get it in hand with in the next 2 days.
- sweetbro
17 Aug 2012 14:06
Got the seat on! Sadly, the foam was WAY too soft, so I gutted my KZ650 stock seat and filled it with that for now, but other than that, its great. (the shape is a little off cause the hack job I made on the KZ650 foam doesnt fill this cover properly)
I'm very happy with the color tho, I hope O can find grips that will match. I will post more pics when I get a really well fitting foam pad in there. Next step is to take the whole thing down to nothing and paint it. We shall see how lazy I am and how long until that happens.
