Stu Pidasole's Build
- kz1k
- You Cant Fix Stupid!
Re: Joe's '78 kz1000 build
23 Jan 2011 14:06
1978 KZ1000A2
- kz1k
23 Jan 2011 15:00 - 23 Jan 2011 15:03
1978 KZ1000A2
Last edit: 23 Jan 2011 15:03 by kz1k.
- larrycavan
23 Jan 2011 15:10Please Log in or Create an account to join the conversation.
- z1kzonly
23 Jan 2011 15:55
rslingshot wrote:
Hey Slingshot, That is some masterful tig weldinG!!!
I knew the Master "Puppet", who built dragbike chassis's since the 70's! "God Speed PuP"
People around the world said "he could weld stainless steel to toilet paper"
He "PuP" would have complimented that welding!
Just my opinion!
My first car tire chassis had 2 pieces of "C" channel, stick welded together to make rectangular tubing, for the hardtail swingarm. And a homemade 2 piece, aluminum wheel hub for an offset car tire, 8" Centerline rim with a 9" goodyear. Too bad I don't have any digital pics of it!
Oh yea! The backbone fuel tank was 1-1/2" schedule 40 black pipe too! With a 3/8" brass, ball cock, gas valve.
Talk about a low budget dragster! It went 6.0's in the 1/8
lemo32 wrote:I am enjoying the sh@t out of this thread, it"s like watching the the little guys hit the ball at pony league, everyone yelling "HIT THE BALL" kids all sweating and nervous and sh@t, this is one for the archives!
Rarely do I comment on someone's build telling them how to do something unless they ask, but like I said I was reading through the thread and seen Joe going in a direction of a bad situation. So I just made a suggestion on replaceing the lower frame cross member he had cut in half insted of scab welding it together. I could care less what he does but I thought I would just spare him some griff down the road.
Just my opinion!
- larrycavan
24 Jan 2011 05:05 - 24 Jan 2011 05:15
testarossa wrote:
There's not a thing wrong with that lower tube for the shock mount if it's done correctly. I've got 5000 miles on one to prove it. But hey... WTF do I know. I've only already done this and ridden the bike 5000 miles :S
For starters, the lower tube gets rejoined using a slip fit inner tube that is welded in. The lower shock mount is 3 pieces welded together, the two tabs and an arced plate that forms to the cross member.
That arced plate is then welded to the resectioned lower rail. This not only gives more than sufficient strength, it gives you liberty to position the mount exactly where you want it to obtain the ride height you want and keep the dog leg parallel with the riding plane.
Anyway, that's how I did mine. It's done. It goes straight down. And no...we weren't smoking dope when all this was done :woohoo:
One other consideration to the particular tube that you cut in half. You will be asking that tube to preform a duty that it was not originally engineered to do. That is to take the load from the lower shock linkage. Therefore, there will be additional and constant stress on that tube. Before it just tied the frame together and occasionally held the bike up on the center stand. I'm sure that the tube is plenty strong, but by trying to weld it in the center you are creating a weak spot where it needs it least. Please know that I am not criticizing your welding skills. Lord knows you are probably a better welder than I am. It won't cost you really anything to ensure that you have a solid tube in there. I bet you could find a scrap piece that long at a steel yard. My local yard sells scrap for 50 cents a pound. What is that $2, dependent on the length of the piece that you buy? Just my .02.
Last edit: 24 Jan 2011 05:15 by larrycavan.
- testarossa
24 Jan 2011 05:49
I hear you Larry. I can't argue with the fact that your's has held together for 5000 miles. However, having seen how the upper mount was going together, I wouldn't think that he was going to brace it inside and out, the way that you did. I always try to err on the side of caution when advising others, and that's why I made this statement. In general I like less welds. Less chance for something to go wrong.
Just curious here. How did you get the inside, slip fit tube in there, and how long is it? Did you spread the frame further, or remove one side? Yikes, lots of innuendo possible with that question, but I'm being serious.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- kz1k
24 Jan 2011 12:08 - 24 Jan 2011 12:09
1978 KZ1000A2
Last edit: 24 Jan 2011 12:09 by kz1k.
24 Jan 2011 12:41
good goin joe.
here is a pic of how ma kaw decided to do there mono shock mount for reference.
(stolen from turbo guzzis thread)
- kz1k
24 Jan 2011 13:05
thats diff. looks like factory mount.
1978 KZ1000A2
24 Jan 2011 14:00 - 24 Jan 2011 14:00
maw kaw=factory
now ya know!:laugh:
now ya know!:laugh:
Last edit: 24 Jan 2011 14:00 by 531blackbanshee.
- kz1k
24 Jan 2011 14:02
531blackbanshee wrote:
:laugh: whats the line attached for?maw kaw=factory
now ya know!:laugh:
1978 KZ1000A2
- andy9802gt
- If it tastes that good, eat it yourself.
24 Jan 2011 14:08
remote ressy for the shock
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
