Stu Pidasole's Build
- porchev914
Re: Joe's '78 kz1000 build
22 Jan 2011 16:35
Use tubing, not pipe please
FRANKEN Z!
- Rainman
- and a little Kaw shall lead them
22 Jan 2011 16:36
kz1k, triangulated top mono-shock mount reference courtesy porchev914's build thread about page 20.
Recomendation,
Cover plate on top over the two side tabs (same material thickness as the tabs is ok),
two round tubes from the top (closer to the shock mount point the better) angled up and to the outer frame rails (the higher the better).
Clearance for air cleaners?
The object is to transfer the vertical forces of the shock into the frame along the length of the tubes (compression, tubes are strong in this direction) as opposed to resisting the forces by twisting the horizontal mount tube (torque, tubes are weaker in this direction).
The top tubes will also help with the side to side forces (lateral), but side gussets won't hurt.
Good luck,
Jim
Recomendation,
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- kz1k
- You Cant Fix Stupid!
22 Jan 2011 16:49
Rainman wrote:
thanks jim, great description.kz1k, triangulated top mono-shock mount reference courtesy porchev914's build thread about page 20.
Recomendation,
Good luck,
Jim
1978 KZ1000A2
- kz1k
22 Jan 2011 16:57
i think i am going to cut the plate back to where the tabs comming off the top mount will house a small piece of tubing. i will make it off centered, making the right side of the tubing stick out longer due to the left off center of the shock. then 2 pieces going at an angle to the tubing i installed, and 2 pieces off those facing up. thanks for all the visuals guys. it really helps.
1978 KZ1000A2
- RedlineJunkie
22 Jan 2011 17:03
porchev914 wrote:
LMAO! Not to long ago I spoke with Joe on the phone. He knows better than that.
- RedlineJunkie
22 Jan 2011 17:14 - 22 Jan 2011 17:19
Rainman wrote:
Jim,
That is an excellent description of what needs to be done and the forces involved. Your setup is ideal, although I don't know if kz1k is ready to go that far. It is from an engineers point of view (I didn't get my degree, I ran out of dough to feed myself) the pretty much perfect implementation of triangulation in regards to the rear mono shock and I must say "Well Done!". Having been a Ducati owner too, the value of having a true trellis frame has never evaded me.
As far as forces transmitted to a KZ1000 frame, wether they be torsonal or not, may take a bit as the Sea Monster has once again invaded my garage, lol.
Recomendation,
Good luck,
Jim
Jim,
Last edit: 22 Jan 2011 17:19 by RedlineJunkie.
- rslingshot
22 Jan 2011 18:04
Just reading over your build Joe. I think that you should remake the the bottom motor mount and cross brace that a few of the members have suggested. I remaid the one on my frame because the was some damage to the lower frame cross brace, but you have cut yours in half,I feel you will be alot better off if you do this and it will look much cleaner.
pic of new bottom motor mount,cross brace and bottom shock linkage mount
My upper shock mount
Just my .02
Just my .02
- kz1k
22 Jan 2011 18:38
thanks slingshot...gives me some ideas.
1978 KZ1000A2
- Rainman
22 Jan 2011 19:07
RedlineJunkie, yes ir1. The what needs to be done comes from years of experiance and common sense. The why (and the technical terms) come from the formal training.
One of the most knowlegable men I ever worked with was not book smart but extreamly experience wise, he never stopped learning or thought he knew it all. He would say," You learn two things from mistakes, what works and what doesn't, and it'll be you if you keep makin the same ones."
Looks like you best be "Kraken" the cap on that Sea Monster project.
Jim
Jim
Jim
Quincy,IL
Jim
Quincy,IL
- RedlineJunkie
22 Jan 2011 19:43 - 22 Jan 2011 19:47
Rainman wrote:
Whoa buddy! Sounds like you might be having some other issues, lol! Now... If you could spell...... LMAO!
Please define what your problem is and might be able to defer you to the correct proffesional. :woohoo:
Jim
Last edit: 22 Jan 2011 19:47 by RedlineJunkie.
- RedlineJunkie
22 Jan 2011 19:51 - 22 Jan 2011 19:52
And second of all, what the hell seems to be the problem? I never said you were wrong?
Fess up boy, whats up your knickers ,,, kid.
Last edit: 22 Jan 2011 19:52 by RedlineJunkie.
- RedlineJunkie
