Stu Pidasole's Build
- larrycavan
Re: Joe's '78 kz1000 build
22 Jan 2011 06:55
Front end needs to be mounted to the frame before the rear shock mounts are finalized .
I'd like to make a comment about the bong but that's really not my business
Suffice to say I view that thing as an adult binky & adults really should't suck their thumb :woohoo:
- Old Man Rock
22 Jan 2011 07:28
Are you seriously going to use that "Cut" lower cross member for you shock mount? :ohmy:
Joe, seriously speaking, I've stayed out of your post for the most part for several reasons but this is something you need to get spot on for nothing more then safety reasons... Hate to here shit went terribly wrong for you/loved ones on a ride.
With that said...
As these guys have been informing you, get this frame straight and securely tightened up (Welded). Use new pipe, no welding two pieces together type of modding... This needs to be secured...
Cut that sonsabitch out and install a new heavier scheduled pipe with saddle cuts...
Then and only then, get that swingarm/rim dead ass centered for if you don't this is going to be one hell of a ride at high speeds "wobble/tank slapper" thus not good.
Chain to tire versus chain to frame clearance is normally wider distance... If required as Mark 1122 did, have the rear hub milled down for chain alignments and clearances to the sprockets.
Once the frame and tire is spot on, you'll be able to accurately determine mono mount positions.... And you'll truly know your CC sprocket offset requirement.
You can get pissed at me once again if you like but I'm giving you the straight up skinny here young man...
OMR
With that said...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kz1k
- You Cant Fix Stupid!
22 Jan 2011 07:41 - 22 Jan 2011 08:14
Old Man Rock wrote:
omr, heres Larrys build....i think he knows what he is doing man...... www.cyclemadness.com/cmforum/index.php?topic=319.0
:woohoo: look what the cat dragged in!Are you seriously going to use that "Cut" lower cross member for you shock mount? :ohmy:
With that said...
OMR
1978 KZ1000A2
Last edit: 22 Jan 2011 08:14 by kz1k.
- kz1k
22 Jan 2011 10:40
1978 KZ1000A2
- porchev914
22 Jan 2011 10:50
Is your cross brace a piece of angle? If it is, it might be OK. If it were me, I would use a piece of square or round tubing, and I would center it between the rear cradle. This will give your mount much better resistance to the torsional force it will be subjected to
FRANKEN Z!
- porchev914
22 Jan 2011 10:53
FWIW, I agree with OMR, it would be cleaner and more sound over all if you cut out that bottom engine mount and fabbed a new cross brace, shock mount and engine mount.
FRANKEN Z!
- PLUMMEN
22 Jan 2011 11:01
- porchev914
22 Jan 2011 11:03
I think Plummen agrees :whistle:
FRANKEN Z!
- kz1k
22 Jan 2011 11:05
porchev914 wrote:
Larry used the front cradle, so thats what i am going with. i hadnt planned on using the centerstand mounts for a bottom shock mount. im just going through the same steps larry did until i get to the point of mounting the bottom of the shock.Is your cross brace a piece of angle? If it is, it might be OK. If it were me, I would use a piece of square or round tubing, and I would center it between the rear cradle. This will give your mount much better resistance to the torsional force it will be subjected to
1978 KZ1000A2
- kz1k
22 Jan 2011 11:07
porchev914 wrote:
ok, back to the drawing board.:SI think Plummen agrees :whistle:
1978 KZ1000A2
- kz1k
22 Jan 2011 11:14 - 22 Jan 2011 11:16
this is why i never go weld happy....easy in, easy out....
not sure what route to take now...gatta brainstorm.
1978 KZ1000A2
Last edit: 22 Jan 2011 11:16 by kz1k.
- kz1k
22 Jan 2011 11:25
Adam, if you look at Larrys build you can see he used the front cradle...also it looks like he used angle for his cross brace...hard to see.
1978 KZ1000A2
