Stu Pidasole's Build
  • porchev914
  • porchev914's Avatar
Re: Joe's '78 kz1000 build
22 Jan 2011 12:07
#424391
I've seen Larry's build Joe, in fact, I'm pretty sure I read it long before you did :P
But, this isn't Larry's build.....it's yours. Rememeber what I told you? Every build is going to be a little different, and yours is deffinately going to be a little different due to the mods you made to the engine mounts. As always, you can do what you want, it is your bike after all. Larrys a smart guy and I know his build has been road tested and is sound, but you aren't going to be able to copy his build weld for weld.
Are you sure he used angle and not square tubing? Even if he used angle, the way Larry oriented it will be stronger than the way your cross brace is oriented. It's little things like that that can make all the difference. I stand by my original recommendation of square or round tubing though. ;)
FRANKEN Z!
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
22 Jan 2011 13:18
#424401
ill be back with pics.
1978 KZ1000A2
  • kz1k
22 Jan 2011 13:51 - 22 Jan 2011 13:53
#424416
well this is the idea. i went with tubing and plate. i will probably put a gusset in between the 2 plates and then weld plate on the top and botton to avoid any flex. better?:dry:
1978 KZ1000A2
Last edit: 22 Jan 2011 13:53 by kz1k.
  • porchev914
22 Jan 2011 13:58
#424417
I like it better. Do you have any thicker plate? Like stated, you'll still want to box the brackets in.
FRANKEN Z!
  • kz1k
22 Jan 2011 14:02 - 22 Jan 2011 14:02
#424418
yeah i have some 1/2". ill use that for the middle cross piece in between the plates. i might even throw 2 in there. glad you like it better.
1978 KZ1000A2
Last edit: 22 Jan 2011 14:02 by kz1k.
  • RedlineJunkie
  • RedlineJunkie's Avatar
22 Jan 2011 14:41 - 22 Jan 2011 14:44
#424428
Here's my thought. Triangulate it. Add two more pieces of steel plate as close to the pivot point back to the frame on an angle as close to 45 if you have the room.
Last edit: 22 Jan 2011 14:44 by RedlineJunkie.
  • kz1k
22 Jan 2011 15:16 - 22 Jan 2011 15:20
#424432
ouch, you made my head hurt. :laugh:
which pivot point? can you explain more?
oh i think i get it. you meen weld a plate from the plates as close to the shock top mount anggled at a 45 towards the ends of the crossbar?
1978 KZ1000A2
Last edit: 22 Jan 2011 15:20 by kz1k.
  • RedlineJunkie
22 Jan 2011 15:37 - 22 Jan 2011 15:42
#424437
'Zactly! That'll keep the mount from moving laterally and will be strong as hell. The vertical thickness of the plate will prevent vertical movement as you designed it but with the addition of the triangulation, you'll double that and prevent lateral movement as well.
Last edit: 22 Jan 2011 15:42 by RedlineJunkie.
  • kz1k
22 Jan 2011 15:42
#424438
'Zactly! That'll keep the mount from moving laterally and is strong as hell. The vertical thickness of the plate will prevent vertical movement as you designed it but with the addition of the triangulation, you'll double that and prevent lateral movement as well.
10-4 joe.
1978 KZ1000A2
  • porchev914
22 Jan 2011 16:20
#424446
I would use tubing if you have it, instead of the plate. Here is my top shock mount Joe, with the triangulation that redline was talking about
FRANKEN Z!
  • kz1k
22 Jan 2011 16:31
#424451
sweet, thanks for the photo. yes i may just use pipe. ill get some progress pics up tomm afternoon i hope.
1978 KZ1000A2
  • RedlineJunkie
22 Jan 2011 16:35
#424454
Round tube in combo with the flat plate you already have mocked up would great. Nice suggestion porchev914! B)
