BACKYARD BOBBER!!!!
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: BACKYARD BOBBER!!!!
18 Nov 2011 17:53
#489128
KZ250LTD wrote:
uglee wrote: Otay so no word on the carb holders???
I have a friend who was molding his own and planning on eventually selling them. I'll check in with him and see if he's made any progress
Found one listed on eBay. It's brand new. Maybe you can get lucky and find another one (your bikes a twin right?).
Carb boot thingy
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • clutch
  • clutch's Avatar
18 Nov 2011 17:59
#489129
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationA couple more. I'm not sure what year yours is...
Wish List:
  • uglee
  • uglee's Avatar Topic Author
  • New 2da game but Tru 2this thang!!!!!
19 Nov 2011 01:48
#489171
Thanks for the ebay listing guys will see if they will pull some measurements for me...... Kz250 hope your friend comes thru cause he is needed by a few 400 owners..... For more recent progress I will try this in the morning.......
Pipe welded to flange
Old radiator hose clamped to carb
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
19 Nov 2011 02:30 - 13 Feb 2012 17:48
#489174
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:48 by KZ250LTD.
  • uglee
19 Nov 2011 15:26
#489219
Okay guys and gurus of kz rider I got the thing to run but it has the runs!! Shot this milky brown oil out the air box....Whats the matter with it? Smoked really hard also....need new piston rings and a good valve job right? Man,i have my work,cut out for me now
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
19 Nov 2011 15:42 - 13 Feb 2012 17:48
#489220
79 KZ1000ST
Past:
Many.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
19 Nov 2011 16:00
#489223
Is your petcock working properly in the off position? Check your oil level and see if its too high. Also open the oil fill cap and smell for gas in the crankcase. Change the oil if does (after making sure your petcock is in working order). Then you should also make sure that your float levels are set properly and your float needle and seat are functioning properly.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
19 Nov 2011 16:14 - 13 Feb 2012 17:48
#489225
79 KZ1000ST
Past:
Many.
  • uglee
19 Nov 2011 18:40
#489239
That oil was blowing out the vent tube. Didn't think to go thru the fluids until I was sure it ran. So how do you flush an engine??
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
19 Nov 2011 20:29
#489254
Simply do an oil change, filter and all (assuming you have gas contaminated oil). Did you confirm you have gas in your oil (crankcase)? Did you check the oil level. My level was good and then rose due to the extra fuel that made it into the crankcase. I could also smell it from the filler cap hole. Is that what you are experiencing? If so, fix your fuel issue first then worry about change the oil.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • uglee
20 Nov 2011 01:59
#489296
There is an oil smell but I was always told the milky brown was an indication of water. Gonna do this oil and filter come Monday wish me luck!!
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
20 Nov 2011 03:14 - 13 Feb 2012 17:47
#489303
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 17:47 by KZ250LTD.
