BACKYARD BOBBER!!!!
- uglee
- New 2da game but Tru 2this thang!!!!!
Re: BACKYARD BOBBER!!!!
08 Jan 2013 22:33
well made some progress!!!! pvc still holding up after 2 days in the gas so feeling optimistic. wat should the angle of the carb be? level? slightly up or down???
mock-up
mock-up
Attachment pvc4.jpg not found
Attachment pvc5.jpg not found
Attachment pvc6.jpg not found
- fivestring
09 Jan 2013 10:19 - 09 Jan 2013 10:44
They obviously will work at other angles so a little lean one way or the other shouldn't matter. I would think the carb is designed to be operated with the fuel bowl being as close to level as possible to work best.
Looks good so far. And if there is a deterioration of the material over time, a quick stop to Home Depot buys you a new one! I love using PVC for all kinds of stuff.
Looking at your design, it seems the fuel delivery should be balanced, but when you get it running, you should check to be sure both cylinders are getting roughly the same amount of fuel. Spark plug checks, header temp check while running, etc. We don't want a lean fuel mix messing up a cylinder.
What does the inside look like? Any places where there is an edge exposed, like the end of each fitting, will reduce the flow of the gas/air mixture. When you port and polish a head, for instance, the idea is to remove any surfaces that interfere with a perfectly smooth air flow. The inside of that intake should be like one long, smooth pipe for best performance.
Just food for thought.
4 out of 3 people have trouble with math
Current
1978 KZ1000A2A, hardtailed, bobbed and stretched
my build thread
1977 Yamaha XS750 (parting out)
1978 Honda CB750 Four
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Kawasaki CSR750
1980 Suzuki GS850L
1982 Suzuki GS1100K
1987 Suzuki GSXR1100
1985 Suzuki GV1200 Madura
1981 Yamaha 650 Midnight Maxim
1972(?) Suzuki GT380
1972(?)Yamaha RD350
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1972(?)Yamaha RD350
Last edit: 09 Jan 2013 10:44 by fivestring.
- uglee
09 Jan 2013 14:35 - 09 Jan 2013 15:04
thinking about adding some type of apoxie JB weld..... some sort flow improvement on nxt prototype
Not at the cranking part yet with all my other irons in the fire.... maybe the weekend will be good to me
Last edit: 09 Jan 2013 15:04 by uglee. Reason: Adding txt
- ramtough_63
09 Jan 2013 15:05
i am runnig a single carb with pvc intake on my gold wing interstate 1299 for laST 3 YEARS I painted it black but performs fine and so far has held up
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- uglee
09 Jan 2013 17:52
so ram it holds up to gas,heat and time??!!!! man i might try firing it up tonite!!! thanks for to confidience boost
- uglee
09 Feb 2013 00:02
Finally got carb on and leaks stopped. It runs but I can't get it to idle plus its very rich. Anybody got ideas on wat to do?
- fivestring
09 Feb 2013 01:33
Will it idle if you spray a wee bit of fuel into the intake to keep it going or is it flooding at idle? I would try holding your hand over most of the intake to limit the amount of air it is getting.
Gotta figure if it is getting too much/little fuel or too much/little air. If too much fuel then idle mixture screw needs leaned way out. Other jets may be in order.
Not very scientific help, more a trial and error thing.
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1972(?)Yamaha RD350
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1972(?)Yamaha RD350
- uglee
09 Feb 2013 11:02
5string at it again!! Thnx 4 the reply... It idles but way to high tried the adjustment but it boggs down when all the way in and sloppy throttle response. Gonna try and find a pod filter then chk jet sizes other guys have used. Think this carb is off a 250 not 125 like others have used. Ebay buys sometines suck!! I smell fuel really bad so I know it's running rich. Jetting is gonna be trial and error as u(5string) said:'(
- fivestring
10 Apr 2013 08:27
Any recent progress?
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1972(?)Yamaha RD350
Current
my build thread
1981 Yamaha XS650
1982 Yamaha XS650
Former
1980 Suzuki GS850L
1982 Suzuki GS1100K
1972(?)Yamaha RD350
- uglee
14 May 2014 19:51
Man I can.t believe its been a whole freaking year.........F*<K time flies even if its been a hard fu<king drive. No progress on the bobber as I have admitted to being a damn HOARDER..... Got 6...I repeat 6!!!! Kawasaki projects now. I just don't have the time or honestly the cash to get my shit together.
In a year all I got done was mocking up the tank and seat........ yeah my skills aint that good but I'm an able mechanic/fabricator.
Pics will be posted in a few days.
Plus this MF-ing DISASTER !!!!!
Attachment 49chevy.jpg not found
