Mono Shock project posts
- ready2ryde1985
- got to love these kzs
Re: Mono Shock project posts
17 Oct 2010 17:06
That is sweet how did I miss your build thred?
I get alittle freaked out when I dont have things strait I want to stock pile parts and build as smooth as I can !
So far as I said I have a swing arm that looks some what like yours and the caliper and brake line .
Gona be a long time comin.But I think I can pull it off.
Pic of my kz in sturgis
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- larrycavan
17 Oct 2010 17:18
ready2ryde1985 wrote:
You can do it. Just don't give up. At first it's a monumental task but how do you eat an elephant..... One bite at a time
- porchev914
17 Oct 2010 18:58
Sometimes, not having all the parts at hand can be a blessing in disguise. It allows you time to really think about what you're doing, asses your direction and construction. I know there were several parts of my build that I had decided about at the offset, only to change my mind later after reading, thinking, figuring, experiencing. Each man has his own method, and I'm with you....it would be nice to have all the parts to just get it done start to finish. There is something to be said for slowing down A.D.D. types like myself :laugh:
FRANKEN Z!
- ready2ryde1985
17 Oct 2010 19:44
So far I know I will need forks and wheels , brake calipers brake lines off set sprokets and new chain to name a few also
rear shock
how does the swing arm and lower shock mount work?? does the lower mount bolt solid ???
Does this shock hang down ?? Do I have to worry about it draging ???
:huh: sorry to sound so clue less just dont know much lol
rear shock
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
- testarossa
17 Oct 2010 20:02
Swingarm pivot will be in the same place as the stocker. The bottom end of the shock mounts to the linkage. The front end of the linkage mounts to tabs that you will add to the frame. Those tabs will be close to the center stand mount location. Yes the shock will hang down a bit, but it shouldn't hit anything. Unless your upper mount lets go.
rear shock
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- ready2ryde1985
17 Oct 2010 22:25 - 17 Oct 2010 22:27
I think this is something that is gona be worth it !!
I will have the stock swing arm out for bracing and mabie add an inch or two to it this winter that will give me time to mock up the 636 swing arm and get a better Idea.
I like the 7 spoke rims why dont I see them on the kz conversions??
Also good news I have found a guy to lay down some pinstriping lol its gona be the $hit! Yellow base Green wavie stripes (is wavie a word lol) orange and black crazy pinstriping, with eye balls worked into the paint like they are floating in and out of the desigen
Found my painter at a school art show walked in to some awsome crazy out there pinstriping. I will get a pic of the desigen I picked out ass soon as I can
Sorry for jacking this thread it was a right time thing I have been reading the mono shock conversions for weeks and this was hear when I returned lol
84 kz 700 a1
82 kz550 ltd
82 kz550 ltd
Last edit: 17 Oct 2010 22:27 by ready2ryde1985.
- Bdog
- Sweep the leg johnny!!!
18 Oct 2010 08:37
It seems to me that the suzuki parts work better. The pivot point of the swingarm is normally narrower than the stock KZ, easier. Some of the early GSXR triple tree stems are almost a bolt on situation, easier. The fronts for me have been the easiest, I had a katana 750 on my 650, now zx6r. I love the way my bike will look this spring, I just need to drop another 500 or so dollars for the parts to get it there!!!
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- kalbo0099
20 Oct 2010 14:22
I kno its not to everyones liking but this build of mine is a bobber KZ1000p with mono-shock rear end. Swing arm came off Kawi 07 ZX6R, and so as the front forks.
- testarossa
20 Oct 2010 14:26
Lets see some more pics kalbo. I'm interested.
2004 ZX-10R
Angola, IN
2004 ZX-10R
Angola, IN
- kalbo0099
- kalbo0099
- kalbo0099
