Mono Shock project posts
  • porchev914
  • porchev914's Avatar
Re: Mono Shock project posts
11 Oct 2010 20:41
#406069
Zedone wrote:
Porsche914. Where did you get the swingarm & where are the wheels from? Nice looking bike for sure.... actually nice work on all the monoshock bikes guys! Doug
The swingarm and wheel are both from an '08 Triumph Speed Triple. I got the parts from a bike salvage yard in Long Beach. It wasn't a walk in the park though, I had to widen my frame 1.5" :whistle:
FRANKEN Z!
  • TerryK
  • TerryK's Avatar
11 Oct 2010 22:07 - 11 Oct 2010 22:11
#406078
testarossa wrote:
Not quite done yet:
Awesome.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 11 Oct 2010 22:11 by TerryK.
  • jus1975
  • jus1975's Avatar
  • www.tripleaperformance.com
12 Oct 2010 15:33
#406198
how do you mono shock guys like the ride. is it a difference. How about stability.
  • ready2ryde1985
  • ready2ryde1985's Avatar
  • got to love these kzs
12 Oct 2010 16:39
#406222
I realy have liked the idea behind all this, and have been making parts lists, this is a thred I will be watching closely thanks guys all the bikes look bit<hin !!
84 kz 700 a1
82 kz550 ltd
  • testarossa
  • testarossa's Avatar
12 Oct 2010 16:58
#406226
I have yet to get my bike past 45 mph, but so far, I am well pleased with the ride. I can take a corner in my neighborhood at a reasonable speed with no drama. I hope that my bike is stable at speed since I went to the trouble to brace the frame in so many places.
As far as comparisons go, I can't compare it to the original KZ ride. Never rode my bike stock. I can compare it to my 2004 zx-10r. It is much more plush at the moment, but that's just how it's set up. I doubt that it will ever corner as well, but there is a lot more clearance, and less weight on the newer bike.
I will say this much about my build. I have done everything in my power to "get it right." My whole suspension came from the same bike. (1995 GSXR 750) The front fork was rebuilt with new seals, new oil, and the correct Race Tech springs for the weight and intended use of the bike. This was the heaviest springs that Race Tech offered for said GSXR.
The rear suspension was all grafted to the KZ with the same attachment points as measured from the original GSXR frame. Again, the rear shock was rebuilt with the correct Race Tech spring, new oil, and I installed a Gold Valve kit to replace the stock dampening piston at the time.
I really like the modern suspension since it is adjustable for preload, rebound, compression, and ride height.
Here are the links to my rebuild threads:
Front fork is here: Teardown: kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=341303
Rebuild: kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=353185
Rear shock is here: kzrider.com/index.php?option=com_kunena&...ew&catid=5&id=398379
Hopefully I can report on highway speed handling in the not too distant future.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • testarossa
12 Oct 2010 17:17
#406230
Here's a couple of shots to show the swingarm mounting:
Obviously everything is just tack welded at that point. It has all been fully welded now.
In that last image, you can see the base of my battery box. More on this in the next post....
2004 ZX-10R
Angola, IN
  • testarossa
12 Oct 2010 17:30
#406232
As for my battery box, I chose an AGM battery of comparable size to the stock battery. This allows me to turn the battery on it's side. The battery box has standoffs that are welded into the frame rails at the back and the floor of the box is welded to the X just above the crossmember for the mono-shock.
I made the lid of the box to accept mounting points for the regulator, ignition box, and the normal electrical panel with the rectifier, solenoid, and four connector block.
I also included a mounting point for a blade style fuse box at the rear.
I hope this makes sense. I'm happy to walk you through any of it, if you need the help. It's all in my build thread which is quite lengthy. I'm hoping to make a clickable table of contents. If I ever finish the bike. :laugh:
2004 ZX-10R
Angola, IN
  • Blackout
  • Blackout's Avatar
13 Oct 2010 17:04
#406443
Thanks for the great ideas keep em commin guys.
I did it myyyyyyyyy Wayyyyyyy
  • Old Man Rock
  • Old Man Rock's Avatar
14 Oct 2010 04:37
#406543
These can be found in mine as well as others project folders...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
14 Oct 2010 04:38
#406544
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
14 Oct 2010 04:39
#406545
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Old Man Rock
14 Oct 2010 04:40
#406546
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
