Tri.... scores one for the barn find column 79MK11
  • DoubleDub
  • DoubleDub's Avatar
Re: Tri.... scores one for the barn find column 79MK11
04 Apr 2011 08:17
#442515
Those Sword Heritage wheels from PMC are just awesome. Too bad they translate to about $3k for the pair without the import costs/taxes.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Apr 2011 14:14 - 04 Apr 2011 14:15
#442574
KZ250LTD wrote:
trianglelaguna wrote: this is the one i think...how would i know though...:pinch:
www.eastwood.com/ew-electroplating-system-tin-zinc.html
Go with caswells!
Yeah, I have the Eastwood kit and it's really just a tin plating kit. The Caswell kit is supposed to be the way to go for home kits. For the finish you want you'll need blue chromate and brightener. However, I got all of this stuff plated for $75 by a local plating company. I also found a place online that will do small quantities for $50, 2 week turnaround. I 'm sending them some parts off my Z1 and some other stuff I forgot for my other project, they also do yellow chromate (cad-type) finish, $50.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 04 Apr 2011 14:15 by Kidkawie.
  • trianglelaguna
  • trianglelaguna's Avatar Topic Author
04 Apr 2011 14:26
#442580
so are you saying the bolt kit you have does not give the right finish..i read on one suppliers site/auction that they said to do the motor/polish gig first on each items as that is where the shine comes form ,knocking down the roguh ,then the tin kit works really well...the plus for me would be...i hope
that i could say...be working on brake pads and set the kit up in a few minutes...buff the bolts and tin...come back and install em...do a bolt here,a set there ,as i find the need to remove tyhem for a task any way..or pull one set a weekend and do em....is the set up and storage easy...is the set up and wait for curing easy...did you buff/smooth them first...
your pics are what got me thinking i want this for my bikes
lot of questions i know....
on some other basket case projects the palting contractor sounds the route for sure...
thanks
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • testarossa
  • testarossa's Avatar
04 Apr 2011 14:51
#442594
I totally wish that I had all my bolts re-plated before I assembled my bike. Now I'm in the same boat. I will have to do a few at a time or just replace as I go to really get the 100% finished look that I want. No big though, I have time. I'm interested in one of these kits as well.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Apr 2011 14:51 - 04 Apr 2011 14:57
#442595
No, it's not the right finish. The finish from the Eastwood kit looks like aluminum, it's only a tin plate. If you look closely at original/new hardware you'll see it has a blue hue to it. That's from the chromate.
Here's a pic showing the difference: i114.photobucket.com/albums/n248/Jeekinz...20KX250/IMG_0129.jpg
Look at the difference: i114.photobucket.com/albums/n248/Jeekinz...20KX250/IMG_0486.jpg
There's also no brightener which is why they tell you to polish them. Just like anything else, the polish will eventually dull out. It's also very time consuming. Unless you build a barrel you have to string each piece of hardware seperately. One M10x40 bolt take about 3 minutes in the electrolyte, then a minute in clean water, then you have to polish it. $75 is cheap after doing a couple dozen parts, trust me. The only pain about sending stuff out is you will probobly (hopefully not) forget something. My local guy said the minimum charge is $75, that covers about a 5 gallon container of hardware. So if I were you, I'd strip my bike down, clean and send out everything including axles, chain adjusters, etc. That's all the stuff I'm going to gather for my next grouping.
1975 Z1 900
2004 KX125
Last edit: 04 Apr 2011 14:57 by Kidkawie.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Apr 2011 14:53 - 04 Apr 2011 14:54
#442596
Oh, that paint is killer! reminds me of something though.....B)
1975 Z1 900
2004 KX125
Last edit: 04 Apr 2011 14:54 by Kidkawie.
  • trianglelaguna
04 Apr 2011 16:10
#442610
well then...you sure saved me from making an error..i get nervous buying something that i have no experience on....thanks you very much....
i like your idea and i may have to look into a local place....
i also was thinking...that i should just order new bolts and nuts on most of this stuff a few weeks before do a task..i mean there are only so many that are exposed and some can even be matched through fastner supplies...just thinking out loud...order new handle bar bolts...new fork clamp..motor mount ones..i have a good kawi shop that orders stuff cheap...wonder how many7 bolts it takes to get to 75.00 ...caswell is something too to consider...i really only have a few that are realy bad...but when that body set goes on it is gonna make others pop out too i bet
once again thanks
anyone uise the caswell kit that was mentioned?????????
1976 KZ900
2003 ZX12R
2007 FZ1000
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
04 Apr 2011 16:23 - 04 Apr 2011 16:28
#442617
trianglelaguna wrote: wonder how many7 bolts it takes to get to 75.00
Not many.
It really depends on how deep you want to go into details. I have OCD, so it bites me in the ass. for my Z1 I replaced alot of bolts from Lowes, only problem is they have markings on the heads where the original hardware was plain. That's your cheapest route and you can swap them out at your leisure. I saved the original hardware and sent it out to be replated along with all my MX extra nuts and bolts. If it's a special piece of hardware, say something like a suspension bolt, then they can cost upwards of $35-45. That KX project I'm working on, the suspension linkage bolts were $17 ea, so it made sense for me to replate them.
If you find you need alot of the same size bolt then check out Bolt MC Hardware. www.boltmotorcyclehardware.com/?gclid=CM...nKg6gCFQQ65QoduGlWsg There are like 18 case bolts all the same size on my KX so I just bought refill bags for a coupla bucks each.
Hardware is probobly the single most frustrating & costly aspect of a restoration aside from sourcing oem/nos parts.
1975 Z1 900
2004 KX125
Last edit: 04 Apr 2011 16:28 by Kidkawie.
  • porchev914
  • porchev914's Avatar
06 Apr 2011 20:59
#443089
trianglelaguna wrote: i am looking for a link to this supplier in japan...anyone ever seen any links or know where this pic came from....
Ran across this site looking for something else entirely and remembered you were looking for oil coolers
Japan bike parts supplier
FRANKEN Z!
  • porchev914
06 Apr 2011 21:05 - 06 Apr 2011 21:07
#443090
Whoops, wrong cooler :blush:
japan.webike.net/products/1538328.html
FRANKEN Z!
Last edit: 06 Apr 2011 21:07 by porchev914.
  • trianglelaguna
06 Apr 2011 21:50
#443102
wow...only 800.000...i was thinking 400...wow...sure is purty though
thanks for the links...
1976 KZ900
2003 ZX12R
2007 FZ1000
  • trianglelaguna
08 Apr 2011 22:31
#443506
So..work is sucking hard...i am leaving to drive in @ 530 am and yawning after sleeping for 8-10 hrs already that night....stupid stress stuff...but...i am super grateful to be working at all...or breathing for that matter...still stress eats it's own portions and will not be spared....
knarley little april showers to bring may flowers...all week...spring is here and the green hills are begging a ride
I shot these from the fourth floor of a parking structure at work....I have been getting entertained by this pair of crows for two years..they are nesting now and this one was buzzing me as i was trying to shoot the clouds and hills...here is the "crows nest" forty feet up in a tree top...
i am outside most of the day and these guys are blast to watch...i have a pocket with unsalted full shell peanuts and the pair follow me and talk all day...
Oh...and i came home to a big box today...wonder what this could be...lets see???
1976 KZ900
2003 ZX12R
2007 FZ1000
