OMR's 1978 KZ1000-B2 LTD
- Old Man Rock
Re: OMR's 1978 KZ1000-B2 LTD
23 Feb 2011 03:10
PVC is schedule 40 1.5" (closer to actual 1 3/8") from Home depot... The PVC collector is a 4" reducer heated and bent into shape.. The exhaust, 3" PVC plumbing pipe... All bent with heat gun (HBT $9.99)
I wasn't worried about crinkles so much as can be witnessed in the 3" bends" but more for riser lengths, working around the oil filter cover, exhaust length/bends for my calculated/desired rpm range (max power band) I want it tuned to....
Risers will be 1.5" O.D. 16g mild steel. I will most likely end up with 1" or 1.5" baffles in a 2.5" off the collector back to the end of the pipe... All welded together one piece design....
Head pipe flange included, won't be any need for split exhaust collars....
As for the collector....
Found this awesome article on pipe cutting angles angles that basically provide the internal bullets inside of the collector....
All of which will try a home made version, it it comes out crap, just buy a prefabbed 4-1 collector and bullet ~ $60...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
23 Feb 2011 04:03
bent into shape?
ive already had your header put on the agenda for next city of omaha plumbing board meeting! :woohoo:
- larrycavan
24 Feb 2011 05:38 - 24 Feb 2011 05:40
You guys should know this all came about because one day Dave's wife got fed up and told him to go pound sand :laugh:
When was the last time anyone saw a Jardine system ?
Last edit: 24 Feb 2011 05:40 by larrycavan.
- Old Man Rock
24 Feb 2011 06:02
So... you and Plumi have been speaking with her again... :blush: Now I hate both of you bastards....
:laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
24 Feb 2011 06:35
larrycavan wrote:
everytime i look at an ltd! :laugh:You guys should know this all came about because one day Dave's wife got fed up and told him to go pound sand :laugh:
- mark1122
- Keep twisting it
25 Feb 2011 19:54 - 25 Feb 2011 19:54
Keep at it bud. you'll get it .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Feb 2011 19:54 by mark1122.
