OMR's 1978 KZ1000-B2 LTD
  • keith1
  • keith1's Avatar
Re: OMR's 1978 KZ1000-B2 LTD
05 Feb 2011 18:58
#428857
Old Man Rock wrote:
So it begins....
Finally got off my ass and got the following accomplished...
* Frame stripped, initial sand blast, frame jig fabbed.
* Engine out of the frame.
* Engine stripped, cases split and initial case cleaning.
Pistons, cylinders, valve/combustion chambers look surprisingly decent...
no expert, but inside looks pretty good to me..clean tranny and lower end.....yo go girl.....:laugh:
  • PLUMMEN
  • PLUMMEN's Avatar
05 Feb 2011 22:20 - 05 Feb 2011 22:27
#428882
B)
Last edit: 05 Feb 2011 22:27 by PLUMMEN.
  • PLUMMEN
  • PLUMMEN's Avatar
05 Feb 2011 22:24
#428884
keith1 wrote:
Old Man Rock wrote:
So it begins....
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
12 Feb 2011 10:46
#430207
PVC Template for the most part complete.... :blink:
Still have some required tweaks & other ideas I want to try but this should be enough to get me going...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Old Man Rock
12 Feb 2011 10:49 - 12 Feb 2011 10:51
#430209
Here Plumi... So you don't have to rotate your head.... :laugh: :laugh: :laugh:
As can be reviewed from this perspective, right after the collector I need to bend upward further...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Feb 2011 10:51 by Old Man Rock.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
12 Feb 2011 10:54 - 12 Feb 2011 10:54
#430211
Sorry Omer, but me thinks she hangs a bit too low... though i could be wrong. Hard to tell without the extras.
Real nice job on the bends and result, but I would want that tucked up nice n tight, then use some heat wrap underneath like the racers do.
What!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 12 Feb 2011 10:54 by TeK9iNe.
  • camaroguy
  • camaroguy's Avatar
12 Feb 2011 12:47
#430229
dosent look like the pan is on it yet. might make a difference
  • porchev914
  • porchev914's Avatar
12 Feb 2011 14:58
#430250
Looking like a good start Old Man, you'll be here in NO TIME ;)
FRANKEN Z!
  • larrycavan
  • larrycavan's Avatar
12 Feb 2011 15:05
#430254
Good Start Dave :)
  • PLUMMEN
  • PLUMMEN's Avatar
12 Feb 2011 21:25
#430332
bending pipes over tree stump eh? :laugh:
  • Old Man Rock
13 Feb 2011 06:40
#430375
Naw, was thinking of using your old thick RANGER head.... That be about the same density as a tree stump.... :P ROFLMFAO!!!!!
OMR knocks on Plumi's door... Hi Plumi, Hi OMR BAM... Perfect bend... :laugh: :laugh: :laugh:
As mentioned, yup, have some additional tweaks such as Tek mentioned raise tighter to frame, and re-work the tail exhaust bends... I'd prefer less bend angles for flow and ease of work involved...
The exhaust risers are 32" but most likely will shorten (collector end) to 30-31". Most of the riser length dimensions I have off 3rd party 4-1 exhausts run in this range.
Still have some other ideas such as 2-2 pipes coming out on each side... Think mini Yoshi's.... B)
Obviously, the PVC collector isn't ideal, this was only to simulate & collect all 4 pipes together and give me the mind sight of what will be required in the actual steel revision.
Still have a considerable amount of research and testing to accomplish for the designs I end up with...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
13 Feb 2011 07:43
#430388
Old Man Rock wrote:
...Still have some other ideas such as 2-2 pipes coming out on each side... Think mini Yoshi's....
