A Newbies Adventures in Maintenanceland!
- 9am53
- homebrew, and some bbq
Re: A Newbies Adventures in Maintenanceland!
30 Sep 2010 02:41
yeah I used the gun and had trouble finding the 2+3 F mark and full advance marks, so I took the coil plate out to clean and possibly highlight the marks, but for the 2+3 side there is only a T mark. This is unusual right? I guess I need a new mechanical advancer! lol
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
- Old Man Rock
30 Sep 2010 04:09
Maybe just the way it was designed for this model.... What's the manual tel ya?
Anyway to accurately measure the distance off the 1/4 markings and scribe your own on the 2/3 side?
You have a picture of this advancer of yours?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 9am53
30 Sep 2010 04:47 - 30 Sep 2010 04:48
I have a pic here from my manual that is exactly like the way I have it. The manual only describes how to check timing of 1 and 4, not 2 and 3, it just skips them. I will likely just keep it as is for now, it runs fine, and will just get a new advancer that has all the hash marks on it. The new motor has electronic advance, and I ditched it, so I need a new advancer anyways.
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 30 Sep 2010 04:48 by 9am53.
- Old Man Rock
30 Sep 2010 04:53 - 30 Sep 2010 05:11
Well if the same as the manual then good to go as far as replacing due to missing markings...
What's the manual mention for 1/4 off idle (advanced mark) positions at 3500-4000rpm...
I would think there must be some mentioning of what to look for 2/3 verifications but hey, WTF do I know....
Ah well, at 2/3 fire you should see it at least line up at idle and move ~ the same distance in comparing to 1/4 operations with your timing light....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 30 Sep 2010 05:11 by Old Man Rock.
- 9am53
30 Sep 2010 05:00 - 30 Sep 2010 05:01
Here it is, it continues for another half page, but mentions nothing about 2 and 3
I was thinking you could put a mark on the engine case on the bottom of the plate and use the 1 and 4 marks on it to simulate 2 and 3 marks on top.
'84 GPz900r
'71 CB350
'71 CB350
Last edit: 30 Sep 2010 05:01 by 9am53.
- Old Man Rock
30 Sep 2010 05:11
"I was thinking you could put a mark on the engine case on the bottom of the plate and use the 1 and 4 marks on it to simulate 2 and 3 marks on top."
No, not correct.... Meaning no case mark on bottom side...
With strobe light on 2/3 spark conductor.... The light is aimed at the same window/case timing mark but this time for 2/3 operations on the advancer...
Try this using a black magic marker....
Measure 1/4 T mark, double lines and F marking on the advancer... Then mark the same on advancer 2/3 side...
Now connect timing light pick up clamp to 2 or 3 sparky...
Check at idle "F" mark and at 4000 rpm between parallel lines....
If good to go, scribe the markings on the advancer... Good to go...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- sparkn
30 Sep 2010 05:15
Just out of curiosity, why would you need a full set of marks on 2-3 if you have them for 1-4? The advance does not advance independently. The only reason for any mark at all on the other side is to set the initial timing. Am I missing something here?
1979 KZ650 SR
- 9am53
30 Sep 2010 05:19
The issue is not the advancer per se, but that the pickups can be adjusted independantly (electronic ignition) so there is a chance that the 2+3 pickup is slightly off. So 1+4 could be perfectly set, but 2+3 might be slightly retarder or advanced and might need some slight adjusting to time it correectly.
'84 GPz900r
'71 CB350
'71 CB350
- sparkn
30 Sep 2010 05:27
Right. Maybe I wasn't clear. 2-3 only needs 1 mark, no? Any thing else is just redundant?
1979 KZ650 SR
- 9am53
30 Sep 2010 05:30
right, BUT there is no mark, just the T mark for finding TDC.
'84 GPz900r
'71 CB350
'71 CB350
- mark1122
- Keep twisting it
30 Sep 2010 08:32
sparkn wrote:
X 2
u set the 2 pickups indipendantly , staticly. Done.
then the advancer takes over, so they still fire at the SAME time in relation to tdc. if 1,4 dont time right with the advancer, u turn the whole plate so 2,3 will be adjusted the same amount.
Hope that makes sense.
X 2
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Motor Head
30 Sep 2010 08:45
To set the thing up, first you need both of those pick-up coils set the same in relation to TDC. Both 1-4, and 2-3 have the TDC mark on the advancer. So First set each pick up so that at Idle you have each showing TDC with your light, then advance the whole plate to the 1-4 F mark @ Idle, per manual.
If you have a light with a built in advance feature you can use it to set them the same, Dial or Digital, set to advace of 1-4 @ Idle and make the 2-3 read the same, using only the TDC marks.
Or do like OMR said, measure and scribe, or buy the advancer, as long as it is set correctly the new advancer has maybe a smoother operation because it is new? does it come with any changeable weights/ springs? Is it just the stock curve with a complete set of degree's marked on it? Or be really cool like the Liquid Dampener soaking up crank harmonic's!
