A Newbies Adventures in Maintenanceland!
- 9am53
- homebrew, and some bbq
Re: A Newbies Adventures in Maintenanceland!
28 Sep 2010 16:55 - 28 Sep 2010 16:56
It appears that there is only one nut, and as the wear marks indicate I have been working on the smaller one.
I may have to try the dremel...I have been having bad luck with my dremel tool lately though. One of the brake calipers on this bike had a broken off bleeder screw, so I drilled out the little hole a bit, inserted my screw extractor, and sure enough it broke. I couldn't drill it out because the extractor was harder than the screw, so I tried notching the top and removing it with a flathead. Just like the bloody rotor and this damn nut it was not letting go, so now I am in the market for a new caliper...That reminds me, I need to make some measurements for tri...
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
'71 CB350
Last edit: 28 Sep 2010 16:56 by 9am53.
28 Sep 2010 17:03
If needed, here's a neat way to hold the countershaft sprocket in position while struggling to loosen the nut.
kzrider.com/index.php?option=com_kunena&...5119&catid=21#325119
When drilling out a broken off threaded shank, it's sometimes easier to use a reverse cutting drill bit, which tends toward removing the broken piece as it's being drilled.
28 Sep 2010 17:10
Do you buy all your bikes from Godzilla? :laugh: :laugh: :laugh: :laugh:
- 9am53
28 Sep 2010 17:12
That is a good idea, but I have no spare chain! lol. I am going to return my impact gun and get one that makes more torque, and borrow my neighbors non-shitty compressor and try that after I take the torch to it again. With the impact gun I shouldn't need to lock the sprocket so we'll see. I am definitely going to keep the better impact gun as I fell in love with even the shitty one, just need to get a decent compressor of my own.
'84 GPz900r
'71 CB350
'71 CB350
- 9am53
28 Sep 2010 17:18
Patton wrote:
Well, to be honest I had my doubts when I was picking up the bike....mind you I got it for 250 bucks and it's mostly all there...the guy I got it from races in the canadian vintage association on a Z1 with a really nice harris frame. The guy told me that the association just opened his class up to the J engined kawis...so I asked him why he was using the decade older Z1 engine to race rather than the GPz engine since it was now legal...he kind of brushed it off. Maybe he knew it was a mess! lol
That's ok though, this is all gravy, soon enough the motor will be back to good and I will have suffered through another penniless winter getting it there lol. This is what it's all about for me, earning my summer enjoyment.
Thanks for your help btw, doing this on my own would suck.
'84 GPz900r
'71 CB350
'71 CB350
- mark1122
- Keep twisting it
29 Sep 2010 07:27 - 29 Sep 2010 07:28
maybe u could take the motor to a local garage. have them heat the nut and impact it off. they would have heavy duty equipt. they wouldnt likely charge much.
what do u need for a caliper? front or rear?
i have a spare rear 78, and mags and tires.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 29 Sep 2010 07:28 by mark1122.
- 9am53
29 Sep 2010 07:42
I need a front right caliper for the GPz fork, I need to measure it up and see if its the same as tris off of the 550, likely not, but worth a try. I am hoping to find one at the swap meet this Sunday. If I can't find it I may just find a pair of newer calipers and make custom radial brackets for it.
'84 GPz900r
'71 CB350
'71 CB350
- mark1122
- Keep twisting it
29 Sep 2010 08:16
9am53 wrote:
i hope we dont get rain on sat.
good luck
i see.I need a front right caliper for the GPz fork, I need to measure it up and see if its the same as tris off of the 550, likely not, but worth a try. I am hoping to find one at the swap meet this Sunday. If I can't find it I may just find a pair of newer calipers and make custom radial brackets for it.
good luck
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 9am53
29 Sep 2010 08:20
I was planning on dropping by at shannonville saturday, but I am going with a couple buddies and Chris has a daughter and can't be gone the extra day, so sunday we are doing the iron butt!
'84 GPz900r
'71 CB350
'71 CB350
- mark1122
- Keep twisting it
29 Sep 2010 08:33
9am53 wrote:
Sunday looks cold and dry. 10*
bundle up.
bundle up.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 9am53
29 Sep 2010 16:25
after reading through that "powerbamd" thread today I realized that I have not checked my timing on the bike yet! I got my gun out and checked 1 and 4, and they were perfect, but I noticed that 2 and 3 don't have an timing marks! Is this a mess up on my advancer, or are they somehow taken using the 1 and 4 marks but on the bottom? I tried to look this up as I am sure this has been hashed out a million times but I couldn't find the answer. THanks
'84 GPz900r
'71 CB350
'71 CB350
- Old Man Rock
29 Sep 2010 18:36
"but I noticed that 2 and 3 don't have an timing marks"...
Huh.... :huh:
Not sure I'm understanding where you're just not seeing it with your timing light or the advancer is not working or the advancer just doesn't have any 2/3 markings...
Ok, you have me baffled.... :blink:
Huh.... :huh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
