The Big Block GPz1400 Fuel Injected Monstrosity 26 Apr 2016 20:23 #723165
  • jberger635
  • jberger635's Avatar Topic Author
  • Thank you received: 1
Thought I'd share a bit of info on my big block GPZ build.
Last summer this bike was an '83 GPz1100 that I crashed pretty badly up at my local racetrack. After junking the bent frame, wheels, demolished gas tank the only usable thing I had left of that bike was an engine.
So I bought an '81 GPz frame and around the same time a good friend of mine was selling a 2001 gsxr 1000. I bought the bike and stripped the suspension off of it and modified it to fit the GPz frame. Found a tank from a KZ and tail from a Z1 and within no time I have a rolling chassis,
Bought a 1394 MTC big block with 10.5:1 pistons, modified the 01 throttle bodies to fit the GPZ head, and sent the crank out for welding, balancing, truing, and shot peening.
Microsquirt is on its way, Dyna ARC-2 also on its way, soon ill have a fuel injected GPz1400. Here's a few pics.
Looks like a beater and thats probably how its going to stay for a while. Don't care how it looks so long as it makes a ton of power and is as mental as I think its going to be.
The Big Block GPz1400 Fuel Injected Monstrosity 26 Apr 2016 21:27 #723182
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
That should be a handfull! :woohoo:
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 00:16 #723192
  • wrenchmonkey
  • wrenchmonkey's Avatar
  • Thank you received: 75
Monsterlishesly Awesome! :woohoo:
Where will you hang the "Remove Before Flight" ribbons?
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 11:12 #723266
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
  • Thank you received: 46
What....?
Gratuitous horsepower...?
Ludicrous speed?
Fuel injected monstrosity-ness...?????
Fak yeah!
SUBSCRIBED!!!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 11:37 #723276
  • RODZ
  • RODZ's Avatar
  • Thank you received: 5
In the street!
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 11:50 #723280
  • jberger635
Thanks guys!
One of the big hurdles in any big block project is dealing with the heat from not having space in between the cylinder liners for air to pass through.
As I do want this to be a daily driver and have potential for sitting in rush hour traffic I'm running a dual oil cooler setup. There will be one at the front that will be fed from the factory oil cooler outlet on the case. Then run it in series to the mini earls cooler at the back all with -10AN fittings and hose. From the ear cooler it will tee off to a top end cooler and back into the case to feed the crank. This will be a dry block setup as well.
Dont have the front cooler or the lines done yet. Currently working on cleaning an polishing the exhaust ports and combustion chambers. Not so much for flow purposes but mostly to keep the carbon from forming. Engines will run cooler if there is no carbon buildup in the cylinder head.
With a proper tune, good oil coolers, and good oil flow through the head im hoping this thing will be able to take some stop-and-go traffic.
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 11:51 #723281
  • Ed_in_Miami
Wow.. that's serious hardware...
This is my build:
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 14:04 #723301
  • Puffin
  • Puffin's Avatar
  • Thank you received: 32
Loving this allready B)
subscribed
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 15:22 #723309
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
That was my concern, overheating.
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 16:46 #723323
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
jberger635 wrote: Thanks guys!
Pretty trick project you've got going on. The chassis is coming out really nice. The head and exhaust ports are going to carbon over no matter how much you shine them up. Better to spend the time opening up the intake port throats to 34.5mm and the exhaust throats to 29mm. Take a 60 and push the seat out on the valve face nearer the margin. Those things will let it breath better and help get heat out of the motor in a realistic way. Cosmetics don't do anything but make the eye happy.... JMO
Larry C.
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 17:31 #723326
  • Thank you received: 2829
Is there space to maybe install a small fan behind the rear cooler? Ed
The Big Block GPz1400 Fuel Injected Monstrosity 27 Apr 2016 17:52 #723331
  • 650mod
  • 650mod's Avatar
  • Thank you received: 48
I like where this is going! Subscribed! Definitely interested to see what you pull off with this one :)
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
